View unanswered posts | View active topics It is currently Sat Oct 31, 2026 9:15 pm
Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
So I've finally learned how to use a multi-band compressor..
Post Re: So I've finally learned how to use a multi-band compress
Ahh... well use a spectrum analyzer, find the frequencies that mostly the snare takes up, and boost said frequencies.
I believe if you were to put a band after your high shelf, and dipped at around 12-14k and then dropped the overall high end on your drum bus, it would have a similar effect.
Tue Nov 09, 2010 1:51 am
First off, let me say as someone who listened to the EP multiple times with the original master job that this is much better.
It's much more clear than the original.
However, I will say that there is still too much bass going on, I think you should keep it over-the-top on bass destruction because it sounds great for slam, but maybe just a little bit more tame.
In general, besides the electronic drums, this recording is a fine example of slam with organic, natural production.
The guitars are not like, compressed to all fuck and the bass audibility makes it slam with a fury.
I wish to get a very similar vibe going on GKM's first demo.
Fri Nov 12, 2010 10:44 pm
Holy tits, this shit is crunchy as hell. Remastering AGAIN... :wall:
Fri Jan 07, 2011 1:29 am
To any who care to have the most recent (and goddamn final) mix of this EP: http://www.mediafire.com/?v975sg2ic75w6db
Fri Jan 07, 2011 2:39 am
In the process of caring/downloading.
Fri Jan 07, 2011 3:15 pm
Am at work. Will care later.
Fri Jan 07, 2011 3:24 pm
