View unanswered posts | View active topics It is currently Thu Oct 29, 2026 7:37 pm
Reply to topic  [ 4 posts ]
Snaxie's Analog Summing Test.
Post Snaxie's Analog Summing Test.
3 different versions of Erotic Minion from the previous thread. Same mix, sent through different things.
Version 1 is sent from outputs 7-8 of the Focusrite into the ART DMPA with Mullard 12AT7s and the FMR RNLA on the insert.
Version 2 is the same chain minus the compressor.
Version 3 is straight in-the-box, with SoundToys Decapitator and Logic's opto compressor on the mix bus; my usual chain. Minus the EQ I've taken to using (top end boost around 10+k, low cut around 40hz).
Note these are neither mastered nor normalized and the levels are thus rather low, so turn them up.
I'll give my opinion eventually. I know which one I like better, and why.
https://dl.dropbox.com/u/13184331/Analog_Summing_Tests.zip
Tue Nov 09, 2010 3:33 pm
Post Re: Snaxie's Analog Summing Test.
DL-ing, will listen a bit latarrrr.
Tue Nov 09, 2010 4:00 pm
Groovy. :isay:
FWIW, everything here is hard-panned L/C/R 'cept for some of the drum machine bits.
Tue Nov 09, 2010 4:11 pm
I like version 2 best.
Something about the compressor not being there sounds better to me.
Something about the bass, I think.
Also, the third is my least favorite.
Fri Nov 12, 2010 10:32 pm
