| Snaxie's Analog Summing Test. http://maplifiers.net/forum/viewtopic.php?f=11&t=851 |
| Author: | Snaxocaster [ Tue Nov 09, 2010 3:33 pm ] |
| Post subject: | Snaxie's Analog Summing Test. |
3 different versions of Erotic Minion from the previous thread. Same mix, sent through different things. Version 1 is sent from outputs 7-8 of the Focusrite into the ART DMPA with Mullard 12AT7s and the FMR RNLA on the insert. Version 2 is the same chain minus the compressor. Version 3 is straight in-the-box, with SoundToys Decapitator and Logic's opto compressor on the mix bus; my usual chain. Minus the EQ I've taken to using (top end boost around 10+k, low cut around 40hz). Note these are neither mastered nor normalized and the levels are thus rather low, so turn them up. I'll give my opinion eventually. I know which one I like better, and why. https://dl.dropbox.com/u/13184331/Analog_Summing_Tests.zip |
| Author: | chris_d [ Tue Nov 09, 2010 4:00 pm ] |
| Post subject: | Re: Snaxie's Analog Summing Test. |
DL-ing, will listen a bit latarrrr. |
| Author: | Snaxocaster [ Tue Nov 09, 2010 4:11 pm ] |
Groovy. FWIW, everything here is hard-panned L/C/R 'cept for some of the drum machine bits. |
| Author: | Broseidon [ Fri Nov 12, 2010 10:32 pm ] |
I like version 2 best. Something about the compressor not being there sounds better to me. ![]() Something about the bass, I think. Also, the third is my least favorite. |
