View unanswered posts | View active topics It is currently Tue Aug 25, 2026 5:35 pm
Reply to topic  [ 586 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 30  Next
If 9's are ok I could donate some 9's to you. They are too skinny for me.....
also, coffee is bast evar
Thanks for the offer, but i kenna get along with nines either!
When i started playing, i would even play ernie ball 8s. These days i have no idea how i did that.
Thu Oct 07, 2010 1:09 pm
unnerstan'.. :nods:
I usually keep nines on one of my RG's but even that's getting old.
Thu Oct 07, 2010 1:23 pm
What real men play.
Thu Oct 07, 2010 3:35 pm
Oh well, second chinese neck: also fucked.
I got both of these at the same time for quite dirt cheap when GFS had a bunch of crap they were clearing out. I suppose they are factory seconds from whatever chinese plant. For something like $25 a piece i figured "why not?" Oh well. That's why not. :red:
This second one might be setup-able, once i mess with the nut. But... i had to loosen the truss rod soooo much to get it to straighten out, that the truss rod nut is no longer attached to the guitar. I just pulled it out and set it aside. I also am not 100% sure that the GBE strings are going to play along. :facepalm:
If i can get it set up like that, i will, otherwise, i am going to have to leave all of this stuff alone until i can acquire some not-shit tele necks. :idk:
Thu Oct 07, 2010 4:35 pm
What real men play.
I just bought a pack the other day for my Tele in DADF#AD
Edit: The D'addario version though.
INB4ERNIEBALLVSD'ADDARIODEBATE.
Thu Oct 07, 2010 5:38 pm
I just switched the D'Addario.
Is your project abort if the necks don't work out?
Thu Oct 07, 2010 5:47 pm
Both ernie ball and d addario blow my ass. DR all the way
Edit: K ernie ball is kinda chill, I have some on my gibson but DR for sure
Thu Oct 07, 2010 5:50 pm
What real men play.
I use the D'Addario version, but yes, these or 11s with an unwound G in standard E. :love:
Thu Oct 07, 2010 5:58 pm
Nah, it is just retard. I have a few necks here, but was really hoping for at least one of these two strattish ones to work for this Garbagecaster. So if neither of them will work, the garbagecaster will just go on hold until i am less broke. :idk:
I think i have the second neck working okay at the moment, anyhow. It is hard to tell, because it is strung with the following strings: EADGGG. :D
The G will never tune up to high E. As a result i have it in something like open C. I am using the hateful three saddle tele bridge, so the intonation is always going to be screwy, but i think it might work. The action is a little weird.
Too bad this neck isn't 100% because it is kind of cool. It must be basically what they use for blanks, i.e. before they carve a shape out of it, because the contour is fucking gigantic, fully in the fashion of a baseball bat. :huzzah:
Thu Oct 07, 2010 6:12 pm
Oh, and D'Addarios are Bast.
Thu Oct 07, 2010 6:14 pm
I have never actually taken the time to try out D'Addarios.
I tried Ernie Balls first and never felt any reason to try anything else.
Thu Oct 07, 2010 6:30 pm
What real men play.
Fatass tones in Eb.
I use D'Addarios. Ernie ball strings are too easy to pick too hard and knock the guitar out of tune, and they break easily. D'Addarios don't do that, and they stay not dead for much longer. I have zero experience with DR strings, though. Nobody around here carries them and I'm not going to order strings from MF. I'll save that experience for when I buy something that ships for free so the strings will too. Or I could just buy $100 worth of strings... I'd go through them in about 6 months anyway. :lol:
Thu Oct 07, 2010 8:23 pm
I also use the D'addario 11s on my Talman now.
And if I feel like going fancy with strings, I go DR.
Thu Oct 07, 2010 8:24 pm
What do you have your Talman tuned to?
Thu Oct 07, 2010 8:46 pm
I like the Dean Markely Blue Steels as well. I like the D'Addarios best when they're fresh, but the Blue Steels last longer. My other guitarist uses Blue Steels, and he has good toan. :nods: (He'd better. :red: )
I have DRs on my bass. They're okay, I guess?
Thu Oct 07, 2010 9:35 pm
One thing is for certain: Elixirs always will suck balls. Coat them with junk, they are dead.
Thu Oct 07, 2010 10:24 pm
Oh, and this is what the garbagecaster looks liek at the moment:
Lots of temporary fits. The tuners are temp borrowed from my old Charvette, the volume knob is borrowed from my main guitar, i am going to rout a proper plastic pickguard at some later point, and of course, the shitty neck will probably need to be replaced...
Also, eventually, i intend to replace the pickup with a beefy rail humbucker. When i do that, i will add a second knob to it as well, not a tone knob though, rather, one to dial in whatever amount of coil split. :idea: I am thinking something that will be ridiculous like 15k in full humbucker mode, and a nice standard tele 7k single coil sound. It might be interesting.
Otherwise, the body is promising, though i really wish i had kept it plain wood-colored. It makes a nice light guitar too, all told, just shy of six pounds with the other fucked up neck, and just about 6.25 pounds with this one. :huzzah:
Thu Oct 07, 2010 10:29 pm
Seconded. I use Blue Steels on all of my guitars...I also haven't changed strings on any of them in well over a year. :noir:
Thu Oct 07, 2010 10:35 pm
Well with that reasoning, once you started jerking off.......
Oh and strings I use D'Addario, cheap, and I used different guitars in each project so I change them a lot. I also like 10-52's.
Thu Oct 07, 2010 10:53 pm
