View unanswered posts | View active topics It is currently Thu Nov 05, 2026 1:06 pm
Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3
Can anyone build me a head cab?
Post Re: Can anyone build me a head cab?
knope wrote:
Pics coming soon... right tools make the job quite easy :panic:
*taps toes... looks at where a watch should be on wrist*
Tue Nov 15, 2011 1:56 pm
Tue Nov 15, 2011 3:37 pm
Looking good so far. :D
Tue Nov 15, 2011 4:24 pm
:eyebrows:
very nice
very nice indeed :isay:
Tue Nov 15, 2011 4:31 pm
How are you planning to finish yer box there? :eyebrows:
Tue Nov 15, 2011 5:04 pm
Black tolex :idk:
maybe a plexi front panel to see the tubes glowing? :dildo: :D
Tue Nov 15, 2011 10:40 pm
Yes, some sort of clear front is the correct answer, IMO. Maybe some sort of mesh.
Wed Nov 16, 2011 2:42 am
Make the front look like a microwave oven, you could see the tubes glow
Wed Nov 16, 2011 10:31 am
Any amp that has a "Brilliance" knob is a good amp.
Wed Nov 16, 2011 3:36 pm
Nice! Are you going to try to round the edges, or tolex over them as is?
Sat Nov 19, 2011 7:20 pm
I plan on rounding the edges with sand paper until my patience runs out. Still missing the back panel, chassis support for when I'm removing the chassis, handle, and of course the plexiglass! I'm going to buy wheels for my cab and use its rubber feet for the amp :idea:
Sat Nov 19, 2011 8:31 pm
If you use sandpaper, make sure you use burly stuff, like 60 grit at least, to take as much wood off as possible. Ideally you might want to see if you can score or borrow one of those wood planes that looks like a cheesegrater. Makes it a lot easier when doing that sort of thing by hand.
Like this:
Sat Nov 19, 2011 9:06 pm
A router is the quick way if you can borrow one.
Tue Nov 22, 2011 12:48 pm
But he would have to be mad careful around the countersunk screws, as they would easily destroy a $40+ roundover bit.
Sometimes, i use the handplane/surform just for simplicity, and also for most occasions when i have used screws to hold a joint together(rather than just glue).
The router does a much more consistent clean job though, assuming you don't fuck something up and get a pile of tear-out on a corner, or set it too deep and get a bizarre edge as a result(or tag a nail/screw and chip/destroy the bit).
Tue Nov 22, 2011 12:56 pm
Ah yes, didn't see the screws at the edges!
Pull em out and dowel em :poop:
Tue Nov 22, 2011 1:06 pm
