View unanswered posts | View active topics It is currently Tue Aug 25, 2026 4:39 pm
Reply to topic  [ 586 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 30  Next
I love that I am a creative type person, with a Bob from Office Space degree.
Sat Oct 02, 2010 8:39 pm
LOL re: its being as big as a P-Bass.
If you want a USA Strat bridge pickup for whatever, I'll mail it to you.
Sun Oct 03, 2010 8:32 pm
For some reason i have a few strat pickups here. As it is a USA one, you could probably get a couple of bucks for that also. I wouldn't want to take something that was worth something without giving you dollars for it. As i don't have any dollars right now, IMO, you should hang onto it. :lol:
If, however you have any junk thats *not* worth anything, i will certainly take that!
Anyhoo, today i did several things at once, because occasionally, that is just how i work.
Made neck pocket and pickup rout templates for the bizarrely shaped chinese pseudostrat neck i have and the off-shaped tele that i made the other day. Also made a template for cutting a pickguard for the same. Then i routed out all of those things that i made templates for.
Then i cut a tele-ish control plate out of a piece of steel bar i have lying around.
Also, i cut and routed a Mustang body out of some really cheepo pine leftover from a house repair project i did recently.
Just stuck the tele together quicky quick to see if everything is going to fit. Looks like it just might.
That pickguard just is a placeholder made out of some 1/8" plywood. The control plate looks shiny because i just got finished shaping it with files and sandpaper, but it is just regular steel, and i expect that it will rust nicely as it ages. :huzzah:
I still have to shape the edges of the tele/esquire, but i haven't decided whether i am going to take a little more off the top, like i did with Pinecaster I, or if i am going to stick with the standard sharp edged treetrunk proper tele style body edges. :idk:
Yarr. :isay:
Mon Oct 04, 2010 12:16 am
I think that pickguard looks kinda cool ... at least from a distance.
How off is that tele? It looks pretty close :idk:
That looks like some high quality pine for the mustang there :isay:
Mon Oct 04, 2010 1:39 am
The pickguard does look cool, it is just a bit too thick, IMO. It is actually spraypainted with two hammertone colors, first copper and then a dark grey immediately after:
It should go nicely with the control plate once that starts to rust some. I just wish it was more like normal pickguard material thickness instead of 1/8" plywood. :isay:
Mon Oct 04, 2010 1:55 am
Oh, and as for the manner in which the tele is oddly shaped, it is sort of close, but the way it is off, it would be much more obvious if i put a real fender pickguard on it. The horn is slightly oddshaped, and IIRC, the body is ever so slightly squashed heightwise as well. Just means that it needs a bit of jiggering and rejiggering to get bespoke bits and bobs built for it to hide its freakness. :red:
Mon Oct 04, 2010 1:59 am
I think that pickguard looks superspiff.
Mon Oct 04, 2010 2:05 am
I think that is actually the color that i am going to paint the Mustang body there. I stumbled across it in an experiment a while back, and i like it a lot. In person, the way that the reddish copper peaks through the darker gunmetal grey is pretty slickly.
Mon Oct 04, 2010 2:09 am
I must sat that is highly fuckable as far as teles go. Proving again you ARE the Master Tinkerer
Mon Oct 04, 2010 9:15 am
That Tele is gloriously hot. I :love: that pickguard.
Mon Oct 04, 2010 9:42 am
I want a copper guitar so goddamn bad.
Or at least copper plated.
Ok I would settle for copper paint.
Mon Oct 04, 2010 12:21 pm
You could probably do it with some copperplating foil from a craft store. :idea: That would be pretty badass actually. You would just have to clearcoat the shit out of it so that it wouldn't turn your arm green when you played it. :isay:
Mon Oct 04, 2010 12:51 pm
Mon Oct 04, 2010 12:52 pm
That SR looks like it would tear your arm up
Mon Oct 04, 2010 12:53 pm
Mon Oct 04, 2010 12:54 pm
Which reminds me how much i want one of these:
Mon Oct 04, 2010 1:12 pm
oooo shiney :geek:
Mon Oct 04, 2010 1:41 pm
I'll take both the copper Thinline and the chrome Tele, thanks. :isay:
Mon Oct 04, 2010 1:56 pm
I think the tele would be perfect for the Maplitonian Army to redirect lasers to their enemy.
Mon Oct 04, 2010 2:08 pm
Holy shit. A chrome guitar.
As my friend always says: "if it looks like chrome, leave it alone"
Mon Oct 04, 2010 3:09 pm
