View unanswered posts | View active topics It is currently Sun Nov 15, 2026 8:22 am
Reply to topic  [ 20 posts ]
Son of a bitch, i am bored.
Post Son of a bitch, i am bored.
I managed to slice my fretting hand middle finger, with an Xacto knife, in exactly the spot that needs to press against the strings to play guitar. Shit is taking its sweet fucking time healing up.
All i want to do is play guitar right now. :red:
Pigfuckers. :mad:
I suppose i should read something. :wall:
Wed Jul 14, 2010 12:47 am
Post Re: Son of a bitch, i am bored.
Fingers are overrated. I play guitar with the power of my mind.
Wed Jul 14, 2010 12:51 am
Put a band aid over it and fucking play PUSSY
(sorry)
Wed Jul 14, 2010 12:52 am
Tried that earlier, it is too deep, kept opening back up, and got blood all over the neck. :poop:
Wed Jul 14, 2010 12:54 am
GNAR, get moar blood on the neck
Wed Jul 14, 2010 12:55 am
Hmm... all i can do with the power of my mind is ruin things. :idk:
Stitch it closed with fishing line or cauterize it with a soldering iron?
Wed Jul 14, 2010 12:56 am
Your finger, that is, not your mind. Unless you're exceptionally bored. :poop:
Wed Jul 14, 2010 12:57 am
Nah, it hurt like some kind of motherfuck too. The cut is like exactly in line and in the spot that the string goes. If it wasn't bleedy, the string could go into my finger in the valley i cut for it. :red:
Wed Jul 14, 2010 12:58 am
I am leaning that way at the moment actually.
Wed Jul 14, 2010 12:59 am
Good luck with that. You might need an assistant.
Wed Jul 14, 2010 1:01 am
I am thinking that if i could manufacture some sort of jig to sturdily hold the thing point up, i could just sort of lean forward, and let gravity be that assistant.
Wed Jul 14, 2010 1:03 am
There you go! You have a project for the evening. :snax:
Wed Jul 14, 2010 1:04 am
There's probably a drill press or band saw involved.
Wed Jul 14, 2010 1:05 am
lol
Wed Jul 14, 2010 1:07 am
I have this pretty rad thing that is actually both, in the basement, but it is currently out of commission due to a broken pulley. :cry:
I might need to go at this project from a different angle.
Wed Jul 14, 2010 1:13 am
Maplitonian
superglue has worked well when I've had cuts on parts of my body I need to use.
Wed Jul 14, 2010 1:34 am
Invite this guy over, he knows how to party
Wed Jul 14, 2010 8:33 am
You should do an Iommi and make some finger-caps for the time being :idea:
Wed Jul 14, 2010 1:30 pm
Holyfuckawesome.
Wed Jul 14, 2010 1:52 pm
