 Hackintosh Buildtime Prawnshots.
Spread 'em:  Full frontal:  It lives!  It boots?  I am that guy:
| Sun Jun 26, 2011 10:40 pm |
GnarlySheen
 Re: Hackintosh Buildtime Prawnshots.
fukin gnarcore broski
| Sun Jun 26, 2011 10:43 pm |
This might be overkill for a keyboard stand:  Good times will be had by all. In contrast to the keyboard stand, that's a tub of books it's sitting on:  Basically as it stands now, with random boxes of stuff of unknown provenance off to the side. We keep meaning to take those to Amvets. I'm not sure who all that even belonged to originally. The space has been cleaned up a bit since. But I digress.
| Sun Jun 26, 2011 10:44 pm |
It is crushing your traxxx as we speak, broheim.
| Sun Jun 26, 2011 10:47 pm |
Jayhawker
Maplitonian
Joined: Thu Jul 08, 2010 9:46 pm Posts: 400 Location: Wichita/Lawrence, KS
I didn't know people really built Macs like that. Badass man!
| Sun Jun 26, 2011 10:48 pm |
| Sun Jun 26, 2011 10:49 pm |
GnarlySheen
HA sick dude! Stoked. U gunna do the same style as you did on that first little mix or something diffnt?
| Sun Jun 26, 2011 11:07 pm |
Sardocasm
Joined: Sun Jun 27, 2010 9:23 pm Posts: 1650 Location: Cupcakes
That is an entirely proper looking setup.
_________________Member Of The Radium Water Gentleman's League Of Luxury.
| Sun Jun 26, 2011 11:21 pm |
There's more clarity and separation while keeping everything big and mean. I can get a lot more going on here, and honestly a lot of it is analog emulation plugins- Master Tape, G Channel, Decapitator, stuff like that. I have Space Designer now with Logic Pro 9, which is a really cool convolution reverb, and the Lexicon stuff... Basically, I can run all the fun stuff on everything and it doesn't tax the system, where before I had to mix down stems and whatnot. It's a massive improvement in what I can make Logic do. I figured the Mortimer Chang track was as good a test as any. There's actually a lot going on there and the recordings are real clean, so there's something to work with re: polishing, and not of the turd variety (which is never cool or fun).
| Sun Jun 26, 2011 11:42 pm |
GnarlySheen
 |  |  |  | Snaxocaster wrote: There's more clarity and separation while keeping everything big and mean. I can get a lot more going on here, and honestly a lot of it is analog emulation plugins- Master Tape, G Channel, Decapitator, stuff like that. I have Space Designer now with Logic Pro 9, which is a really cool convolution reverb, and the Lexicon stuff... Basically, I can run all the fun stuff on everything and it doesn't tax the system, where before I had to mix down stems and whatnot. It's a massive improvement in what I can make Logic do. I figured the Mortimer Chang track was as good a test as any. There's actually a lot going on there and the recordings are real clean, so there's something to work with re: polishing, and not of the turd variety (which is never cool or fun).
Cool, well if you were goin the same route you did as last time, we would def use it as some sort of " dirty" mix since its nothing like weve ever heard lol.... But the main guy who is mixing / mastering our stuff tends to go for the louder, more in your face pushing the limiter to the max rise record style type stuff...... Best way I can describe it.
| Mon Jun 27, 2011 12:02 am |
El-Todgo
Looks very clean inside  My pc innards just look like a computer has vomited into the case
| Mon Jun 27, 2011 4:50 am |
I like the visual imagery going on there.  Putting it into a gigantor server case probably helps with this.
| Mon Jun 27, 2011 9:46 am |
I think it needs more fans.
Could you just, say, mount it all inside of a big box-fan? Or maybe sandwiched between two?
| Mon Jun 27, 2011 9:48 am |
It's actually cooler than room temperature when running. But no, it does not have enough fans. There's space to mount a few more though.
| Mon Jun 27, 2011 9:56 am |
You could put some sort of beverage cooling device in there
| Mon Jun 27, 2011 10:01 am |
I have the space. Perhaps it could have Maker's Mark on tap, and sour mix.
| Mon Jun 27, 2011 10:19 am |
Sardocasm
Water cooling, Snaxie, water cooling.
| Mon Jun 27, 2011 6:33 pm |
| Mon Jun 27, 2011 6:37 pm |
I LOLed at this IRL. I'd also like to add it has some advantage in that it could be cooled to a lower temperature than water. It could also... er, assume a higher temperature than water comparatively, which would be, er, uhhm... a bad thing.
| Tue Jun 28, 2011 8:39 am |
Unstrung
Excellent. Perhaps a couple more plushies are needed, though.
| Tue Jun 28, 2011 11:20 am |
