| FML rectifier Tubes http://maplifiers.net/forum/viewtopic.php?f=2&t=2709 |
| Author: | teh_bleeding [ Tue Jan 01, 2013 9:23 pm ] |
| Post subject: | FML rectifier Tubes |
She wont fit unless I cut out some of the wood. Good thing its homemade
| Author: | Snaxocaster [ Tue Jan 01, 2013 9:29 pm ] |
| Post subject: | Re: FML rectifier Tubes |
t00b fail. Whatchu bild, anyhoo? |
| Author: | teh_bleeding [ Tue Jan 01, 2013 9:39 pm ] | |||||||||
| Post subject: | Re: FML rectifier Tubes | |||||||||
This is that sunn model T that i built ages ago thats collecting dust. Its getting re-trannied and rectifier tubed. And retubed... kt88's are going out for 6550's. |
| Author: | Unstrung [ Wed Jan 02, 2013 1:02 am ] |
Did you make the head cabinet as well? |
| Author: | teh_bleeding [ Wed Jan 02, 2013 1:17 am ] | |||||||||
Nah, got it from weber. Just realized that my post up there was a bit misleading in the verbiage eh? Amp is home made, not the cab or chassis or anythnig liek that >_< I know nothing about woodwork, except that i hvae to cut some notches to get mah t00bs to fit ahahahaha |
| Author: | chris_d [ Wed Jan 02, 2013 1:46 pm ] |
That *almost* looks like it might go in, if you angled it past that ridge for the back panel? The first amp i build i had the same issue, when i was still running a tube recto. but i could make it just barely fit, by angling it in. Taking it back out was a paint in the bllz tho. Luckily i hacked that first cab together out of scrap, so ditching it to hack another one together was only a few hours and no big deal. Of course, shortly thereafter, i ended up going to a wee little SS recto that i built into a tube base, and is all of maybe two centimeters tall.
| Author: | teh_bleeding [ Wed Jan 02, 2013 6:48 pm ] | |||||||||
Nah it wont, the socket sits too high above the chassis. I was looking for bottom mount sockets a la dynaco, but they were all PCB mount and i want chassis mount because i have no way to secure a PCB other than hot glue hahaha. |
