Give me your thoughts...
http://maplifiers.net/forum/viewtopic.php?f=6&t=1383
Author:  torgeot [ Wed Mar 09, 2011 7:16 pm ]
Post subject:  Give me your thoughts...
My '77 LP or this '80 JMP 50 watt 2204?
http://www.thegearpage.net/board/showth ... p?t=849692
I don't really do the 77 it's so fucking heavy and it has those old Overlend actives. Do I need either one right now? no.....
just give me your thoughts
Author:  torgeot [ Wed Mar 09, 2011 7:19 pm ]
Post subject:  Re: Give me your thoughts...
if you've not looked it is a very clean JMP. but 6550's not EL34's.
Author:  GnarlySheen [ Wed Mar 09, 2011 7:47 pm ]
I enjoyed my jmp which had the el's..... WIth 6550's , it could sounds massive!
Author:  chris_d [ Wed Mar 09, 2011 8:14 pm ]
That sounds like a badass amp, but a lot of JMPs are out there...
Your LP is a little more unique. It is the one with the active mini-hums right?
I guess it depends on how happy you are with the LP. Would you like another LP better? Like one with passives, lighter weight, etc? Really it comes down to how attached you are to the guitar.
Also though, it depends on what the value of a JMP happens to be. I thought the 50w ones were still available every now and then on the relative cheap(like, sub $1k)? Granted, this one does look clean(though no gut shots).
I dunno.
Author:  torgeot [ Thu Mar 10, 2011 8:50 am ]
yes Chris, this is my thought. I have already mentioned to the guy I may have cold feet. I love recording with that guitar even though I have to change my settings etc to make up for the active pups. I keep thinking to just change out the pups on it and play it, but it is a heavy beast. Coming across some old wood is hard and I think I'm just going to sell some other crap I'm not using. That would make much more sense. I was starting to lean this way and I'm thinking to just save some cash for another JMP.
Again, I'm not in the need for one with the Shiva which I am totally in love with, it's just a want to have one again.
Author:  Broseidon [ Thu Mar 10, 2011 9:52 pm ]
Can we see the Paul?
Author:  torgeot [ Fri Mar 11, 2011 12:34 am ]
Author:  Broseidon [ Fri Mar 11, 2011 12:35 am ]
Oh damn, that's a badass motherfucker.
Author:  torgeot [ Fri Mar 11, 2011 12:38 am ]
yeah I don't think I can give her up. Temporary lapse of reason.
Author:  Snaxocaster [ Fri Mar 11, 2011 3:59 pm ]
Yes. Keep the LP. Though if you find a mid/late '70s JMP 2204, Canadian model with toggle switches and EL34s on HCAF, specifically if Dark Angel on there is selling it, purchase it post-haste. Twas mine, and sounds epic awesome. Also, really, really fuggin' loud.
Author:  newholland [ Fri Mar 11, 2011 5:54 pm ]
holy shit.. you can't off that guitar. not for some stock assed marshall. :p
you SHOULD however, put proper passives back in it.
man i heart me a norlin deluxe.. maple neck on it? :love:
Author:  chris_d [ Fri Mar 11, 2011 6:05 pm ]
IIRC, tor's axe actually came that way off the line. Note the odd bridge as well. I forget what they called that model, but i think it started that way...
Author:  torgeot [ Fri Mar 11, 2011 7:20 pm ]
the guy I bought it from said they EMG Overlends were stock, Gibson said they didn't sell them that way. so they must be aftermarket. But the battery have a really well done mount riveted in the back control cavity. The guy from EMG said they pups were from 77 or 78. very rare.
I would prefer passives in it, I would like to do a Minihum in the bridge and a p90 in the neck for the variation in tones.
Author:  chris_d [ Fri Mar 11, 2011 8:48 pm ]
Ah, then IDNRC. :red:
Author:  newholland [ Fri Mar 11, 2011 10:39 pm ]
a good friend of mine had a 76ish deluxe that'd been made basically worthless by being routed for normal buckers--- but i swear to god, it's the best sounding guitar on earth.. 5 ply laminated body, maple neck. i always tell him if he ever sells it and he doesn't give me right of first refusal i'll hunt him down and kill him for it. :D
i wanna play it DAMMIT... but if you do off it.. lemme know :D
Author:  torgeot [ Fri Mar 11, 2011 10:50 pm ]
@Chris - I believe I mentioned that I was told the pups were original, so your memory my be recalling this.
@Dan - yes the HEAVY pancake body and maple neck is super fuckin awesome. I knew once I took it back out of the case and played it, It. Could. Not. Leave.
also, a Les Paul that can fall off the stand and not snap the headstock :red:
Author:  eddiemunster666 [ Fri Mar 11, 2011 11:35 pm ]
Keep the guitar. If want a marshall jmp, I'll build it for you. You just supply the parts.
Author:  GnarlySheen [ Sat Mar 12, 2011 12:59 am ]
Sell whatever you can to buy hookers and blow
