View unanswered posts | View active topics It is currently Thu Nov 19, 2026 9:40 am
Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
My new project guitar
Post My new project guitar
will eventually look like:
If only it had a Floyd for pure cawk rawkiness.
Sat Nov 12, 2011 8:39 pm
Post Re: My new project guitar
that sir is very lime. 1 pickup is so rawk. One of my fave guitars had 1 pup 1 vol that's it. Less twiddling moar rawking
Sun Nov 13, 2011 11:54 am
Nice "The Goggles They Do Nothing O Caster" there. :isay:
A floyd would definitely put it over the top. But it is hardly worth a floyd unless you put a big ol' Real (expensive) Floyd in anyhoo. Otherwise you won't be able to tuneit/keepitintune well enough to use it for anything.
In many/most cases, the fixed bridge is the better choice, though much less "bitchin' looking", in a purely aesthetic sense.
Sun Nov 13, 2011 12:26 pm
Plus I would never really use a floyd anywho.
And the body is drilled for the TOM bridge, so despite it's unbitchiness it is what it is. Also, it is pretty solid for the rawkin' I do. Also, it will have a top mounted strat input, which I forgot to include in Kisekae :red:
Now I just got to figure out the pickguard.
Sun Nov 13, 2011 2:43 pm
I wonder what it would look like with a mirror guard instead of a body-matched one ....
Sun Nov 13, 2011 2:46 pm
Sun Nov 13, 2011 3:04 pm
:nods: This assaults my eyes, especially with the mirror guard. Nice.
Sun Nov 13, 2011 4:01 pm
Yeah I can't decide between the slicker looking matched guard or the offensively obnoxious mirror guard. The guitar IS MEANT to be obnoxious, so I am tempted.
Sun Nov 13, 2011 4:03 pm
Mirror for maximum obnoxion, if that's your aim.
Sun Nov 13, 2011 4:49 pm
Sun Nov 13, 2011 5:15 pm
I think this is my fave.
Sun Nov 13, 2011 5:26 pm
Yes, I like your most recent design.
Note though, I think a Fender style guitar will need a good amount of angle on the neck to suit a tune-o-matic bridge. Like the neck pocket would be shaped such that the neck tilts away, so the strings will slope down to the nut in a decent way.
Mon Nov 14, 2011 5:55 pm
The guitar was already built for a TOM, it came stock with it. :D
It is an old SX strat I have already taken apart once before. Essentially doing the same thing I did last time, but I'm also painting it.
But you are correct. I used a slight angled shim in the neck pocket to angle the neck back a bit, otherwise the action gets progressively higher the further up the neck you go. Kind of a PITA, but it is stable when setup right.
Mon Nov 14, 2011 5:58 pm
Oh, cool. :D
What pickup do you have in mind?
Mon Nov 14, 2011 6:21 pm
Oh, cool. :D
I haven't settled on one yet actually, a pretty hot one though.
Maybe that GFS EVH pickup, but I want to look around at some other options first.
Mon Nov 14, 2011 6:25 pm
Oh, cool. :D
EVH pickup... pretty solid choice for a single pickup strat. :nods:
Mon Nov 14, 2011 6:28 pm
http://store.guitarfetish.com/VEH-Vinta ... c_165.html
Mon Nov 14, 2011 6:40 pm
Yesyes!
What manner of music with this guitar would you create?
Mon Nov 14, 2011 8:07 pm
Yesyes!
This is going to be my heavier music guitar. It will be the only solid body I have with a 'bucker, and thus will be used with the more extreme settings of my fuzz: a.) because the higher output will push that fuzz the way it wants to be pushed (it really likes a hotter signal coming in) and b.) because it will be significantly quieter than singles or the buckers in the Talman semi-hollow.
It will also probably get used in most of my recordings.
Mon Nov 14, 2011 8:20 pm
Cool. :unstrung:
Mon Nov 14, 2011 8:33 pm
