| My new project guitar http://maplifiers.net/forum/viewtopic.php?f=6&t=2155 |
Page 1 of 2 |
| Author: | Devtron [ Sat Nov 12, 2011 8:39 pm ] |
| Post subject: | My new project guitar |
will eventually look like: ![]() If only it had a Floyd for pure cawk rawkiness. |
| Author: | torgeot [ Sun Nov 13, 2011 11:54 am ] |
| Post subject: | Re: My new project guitar |
that sir is very lime. 1 pickup is so rawk. One of my fave guitars had 1 pup 1 vol that's it. Less twiddling moar rawking |
| Author: | chris_d [ Sun Nov 13, 2011 12:26 pm ] |
Nice "The Goggles They Do Nothing O Caster" there. A floyd would definitely put it over the top. But it is hardly worth a floyd unless you put a big ol' Real (expensive) Floyd in anyhoo. Otherwise you won't be able to tuneit/keepitintune well enough to use it for anything. In many/most cases, the fixed bridge is the better choice, though much less "bitchin' looking", in a purely aesthetic sense. |
| Author: | Devtron [ Sun Nov 13, 2011 2:43 pm ] |
Plus I would never really use a floyd anywho. And the body is drilled for the TOM bridge, so despite it's unbitchiness it is what it is. Also, it is pretty solid for the rawkin' I do. Also, it will have a top mounted strat input, which I forgot to include in Kisekae Now I just got to figure out the pickguard. |
| Author: | Devtron [ Sun Nov 13, 2011 2:46 pm ] |
I wonder what it would look like with a mirror guard instead of a body-matched one .... |
| Author: | Devtron [ Sun Nov 13, 2011 3:04 pm ] |
| Author: | Snaxocaster [ Sun Nov 13, 2011 4:01 pm ] | |||||||||
| Post subject: | Re: My new project guitar | |||||||||
This assaults my eyes, especially with the mirror guard. Nice.
| Author: | Devtron [ Sun Nov 13, 2011 4:03 pm ] |
Yeah I can't decide between the slicker looking matched guard or the offensively obnoxious mirror guard. The guitar IS MEANT to be obnoxious, so I am tempted. |
| Author: | Snaxocaster [ Sun Nov 13, 2011 4:49 pm ] |
Mirror for maximum obnoxion, if that's your aim. |
| Author: | Devtron [ Sun Nov 13, 2011 5:15 pm ] | |||||||||
| Author: | Devtron [ Sun Nov 13, 2011 5:26 pm ] |
I think this is my fave.
| Author: | Unstrung [ Mon Nov 14, 2011 5:55 pm ] |
Yes, I like your most recent design. Note though, I think a Fender style guitar will need a good amount of angle on the neck to suit a tune-o-matic bridge. Like the neck pocket would be shaped such that the neck tilts away, so the strings will slope down to the nut in a decent way. |
| Author: | Devtron [ Mon Nov 14, 2011 5:58 pm ] | |||||||||
The guitar was already built for a TOM, it came stock with it. It is an old SX strat I have already taken apart once before. Essentially doing the same thing I did last time, but I'm also painting it. But you are correct. I used a slight angled shim in the neck pocket to angle the neck back a bit, otherwise the action gets progressively higher the further up the neck you go. Kind of a PITA, but it is stable when setup right. |
| Author: | Unstrung [ Mon Nov 14, 2011 6:21 pm ] |
Oh, cool. ![]() What pickup do you have in mind? |
| Author: | Devtron [ Mon Nov 14, 2011 6:25 pm ] | |||||||||
I haven't settled on one yet actually, a pretty hot one though. Maybe that GFS EVH pickup, but I want to look around at some other options first. |
| Author: | Unstrung [ Mon Nov 14, 2011 6:28 pm ] | ||||||||||||||||||
| Post subject: | Re: My new project guitar | ||||||||||||||||||
EVH pickup... pretty solid choice for a single pickup strat.
| Author: | Devtron [ Mon Nov 14, 2011 6:40 pm ] |
http://store.guitarfetish.com/VEH-Vinta ... c_165.html |
| Author: | Unstrung [ Mon Nov 14, 2011 8:07 pm ] |
Yesyes! What manner of music with this guitar would you create? |
| Author: | Devtron [ Mon Nov 14, 2011 8:20 pm ] | |||||||||
This is going to be my heavier music guitar. It will be the only solid body I have with a 'bucker, and thus will be used with the more extreme settings of my fuzz: a.) because the higher output will push that fuzz the way it wants to be pushed (it really likes a hotter signal coming in) and b.) because it will be significantly quieter than singles or the buckers in the Talman semi-hollow. It will also probably get used in most of my recordings. |
| Author: | Unstrung [ Mon Nov 14, 2011 8:33 pm ] |
Cool.
