View unanswered posts | View active topics It is currently Mon Sep 21, 2026 11:38 pm
Reply to topic  [ 341 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 18  Next
The workbench thread
Post Re: The workbench thread
Holy shit, Chris.
Those pedal graphics are crazy!
Sat Mar 26, 2011 2:06 pm
fuck it, imagonna build something like this
http://home.polstra.com/amps/breadboard/breadboard.html
Sun Mar 27, 2011 11:15 am
Yeah, that is WAY less sketchy than the 2x4+Nails protoboard.
I know that folks have been using the wood+nail style for a long time, but i don't know if i would use it for anything higher voltage than pedals, given other options out there today. I would always be concerned about the variant/unknown humidity/conductivity of the wood with the high voltage/current running into it. Seems like it would be an easy way to make a radio (inadvertently) though.
Sun Mar 27, 2011 11:22 am
Yeah this looks a lot less electrocuty.
I'm gonna build this up in a big ass roasting tin so that I dont get too bent out of shape over the cosmetics. Will probably use that weird sanecore PT from what I think is a vox ac15cc as it should be able to run 5 or 6 12ax7s without too much problem.
But first I need to finish up this amp build. More on that later hopefully. I got up dick early to watch the F1 this morning and now I'm pooped.
Sun Mar 27, 2011 11:48 am
Got a bit more done on this today:
heaters wired
cathode biasing and screen tag board wired
Board underside grounds wired
If I dont get distracted I'll wire the pots, switches and power in tomorrow.
:poop:
Mon Mar 28, 2011 5:31 pm
I got distracted haha. I got some stuff done though.
Tue Mar 29, 2011 7:32 pm
:dildo:
Tue Apr 05, 2011 6:35 pm
that looks pretty close to functional :panic:
Sat Apr 09, 2011 6:28 pm
Indeed :isay:
I've been ill as a motherfuck the last week so progress has been slow as I'm doing all the bits you really dont want to fuck up now :poop:
Sun Apr 10, 2011 7:10 am
:tu:
Mon Apr 11, 2011 8:23 pm
Just gone to shake down the power supply before wiring up the OT and the controls.
Heaters - check
Filters - check
Power scaling - :cry:
Something aint right. The layout for the VVR circuit looks okay. I've just been through it a few times and it doesnt look like I've fucked it up.
:poop:
Tue Apr 12, 2011 5:07 pm
Could just be that it needs a load to regulate. Also it turns out that the VVR circuit blocks the screen filter cap from discharging when you discharge the reservoir cap :(
Tue Apr 12, 2011 7:25 pm
It turns out that the voltage scaling circuit wont work if there is no load on it. Makes sense if you think about how a MOSFET works I suppose :poop:
Stuck my bleeder tool across the screen cap and voilà! Working VVR!
Wed Apr 13, 2011 12:12 pm
Yey: it makes sound
Boo: pops, farts and motorboating :lol:
Ah well at least the PI and power amp work haha
:poop:
Thu Apr 14, 2011 2:31 pm
I have acquired an oscilloscope which should make trouble shooting a load easier!
Mon Apr 18, 2011 9:08 am
get this bitch working... NAOW!!!!! :mexican:
Mon Apr 18, 2011 9:55 am
Thats the plan :isay:
Mon Apr 18, 2011 10:12 am
Initial titting about with the 0-scope make it look like i'm only getting signal from one side of the PI. Clean channel preamp seems to behave reasonably well for a 2Vpp sine wave. I'll dick with it more when I get back from the gym.
Its pretty cool looking at the preamp signal on the o-scope and twiddling the pots to see the phase shifts and distortion onset.
Mon Apr 18, 2011 3:29 pm
Someday, i will actually turn on my oscilloscope. :red:
In my defense, it is my grandfather's old one (that he built) from the 60s, and probably will need some setup/calibration/cap replacement, so i have been semi-afeared to just turn it on and see what happens. :red:
Also, which map circuit are you troubleshooting here again?
Mon Apr 18, 2011 3:37 pm
The amp I've been building forever :lol:
Mon Apr 18, 2011 7:05 pm
