View unanswered posts | View active topics It is currently Mon Sep 21, 2026 11:38 pm
Reply to topic  [ 341 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17, 18  Next
The workbench thread
Post Re: The workbench thread
They mount with M2.5 hardware. An antislip washer and nut should keep it in place. I have a massive piece of phenolic board on the way (600x400mm) and I have 80 of these crazy little fuckers so I can have a few boards on the go. I'm building a dedicated powderamp into my prototyping rig as I have an OT that wont see use otherwise. Looking at about 45W out of a pair of 6L6s.
Sun Sep 25, 2011 6:49 pm
Back to my previous build. It had an annoying buzz which couldn't be cured with a humdinger so I pulled the whole thing apart and redid the grounding scheme to be a local star bus which should be ground loop free and much quieter. We'll find out tomorrow when I wire the rest of it back up.
Mon Oct 03, 2011 12:07 pm
Fixed the grounding, things are much improved. Now I have a little bit of coupling between the OT leads and the input to sort and its done.
In other news:
:hypno:
Thu Oct 06, 2011 7:21 am
Thats... a lot of capacitors... :hypno:
Thu Oct 06, 2011 8:58 am
Might as well stock up!
:isay: :poop:
The stuff is split between a big muff prototype and my amp protorig which so far has cost more money then I care to add up :o
Thu Oct 06, 2011 9:08 am
Just the switching circuit to do which will be the weekends fun :dance:
:panic: :panic:
Thu Oct 06, 2011 11:35 am
May I add, that is a wonderful looking Vox!
Thu Oct 20, 2011 9:55 am
Its a '68 (IIRC) with 55 Hz H30s in it. I traded a POD UX2 for it :lol:
Thu Oct 20, 2011 10:01 am
Why can't I get a killer deal like that :wall:
Thu Oct 20, 2011 10:52 am
I really need to build a 2x10 cab for the Vox LNT.
tor's old HRD combo cab is working just fine for now though. Actually I am kinda considering trying to turn the LNT INTO a combo using that cab, but the dimensions are all fuckered for that.
If anyone needs an empty 2x10 combo cab though ....
Thu Oct 20, 2011 11:53 am
My AOR is on the bench. Hopefully its just a jack socket that has gone shit as initial tinkering suggests.
Tue Oct 25, 2011 5:24 pm
Does it have the Zozo mod for extra awesomeness? I can't remember if you modded yours or not....
Tue Oct 25, 2011 11:09 pm
Nah I've not fucked with it. Sounds great as it is. I was going to add a depth to the NFB loop but its already basstarded and any more low end is just going to kil OT's at the volume I play at. It does look to have been fiddled with by someone else though and I haven't got another AOR to test it against.
The trannys on it are frigging huge. I have a cheapo 100W OT which is a bit bigger than an OT in a DSL and a fair chunk bigger than whats in the blackstars I've seen. The OT in the AOR dwarfs it.
When I've gotten to the bottom of why its being a shitbag, which does look more and more like the inputs, I might recap it. Its a bit of a faff as it uses a voltage doubler for the B+. It has 2 50+50 µF 500V cap cans for the plates in series parallel which is a bit of a waste of £13 when I could just use 2 100 µF caps in series which would be much cheaper but I'd have to make a board for it and whatnot. Thing is though, 50 µF is fuck all filtering for an amp not using a doubler, let alone one that does!
Wed Oct 26, 2011 5:56 am
So I totally made some clips of the AR-20. My bro Phil is playing my strat in E drop A into the dirt channel with everything dimed :poop:
http://dl.dropbox.com/u/8802910/AR-20_PHIL.mp3
Mon Nov 14, 2011 6:41 am
Its here, bitches!
Wed Nov 23, 2011 9:13 am
So I've been quietly scheming
Wed Dec 28, 2011 8:24 pm
Sexks!
Thu Dec 29, 2011 8:27 pm
I want a 2x10 cab.
Thu Dec 29, 2011 10:25 pm
This is now an interesting shade of red
Fri Dec 30, 2011 9:10 pm
That is fucking hott. What for grillcloth?
Fri Dec 30, 2011 9:39 pm
