View unanswered posts | View active topics It is currently Mon Sep 21, 2026 1:19 pm
Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
I love blurry cellphone pics! (Knope's Hot Cat Build Thread)
Post Re: I love blurry cellphone pics! (Knope's Hot Cat Build Thr
Shit tonne of filter caps is the Matchless/Badcat way!
Also, looks pretty fucking sweet, Knope!
Here's to an uneventfully successful first run! :huzzah:
Sun Feb 27, 2011 8:59 pm
What sort of plate voltage does one of these mothers usually run at?
Mon Feb 28, 2011 8:55 am
Here ya go zozo: :tu:
Mon Feb 28, 2011 10:28 am
Awesome. Good luck on it's first run!
Mon Feb 28, 2011 10:48 am
Sweet. Thats a pretty minimal clean channel :lol:
The temptation to use that AC15/30 PT and the generic OT I have for something like this is pretty high.
You managed to find a recto toob?
Mon Feb 28, 2011 10:54 am
:panic:
Wed Mar 02, 2011 6:08 pm
Zozobra wrote:
:panic:
:panic: :panic: :panic: :cop: :panic: :panic: :panic:
Thu Mar 03, 2011 9:22 am
Sorry... I got sick... but I'm turning it on today!!!!!!
and by today I mean right now!!!!
Thu Mar 03, 2011 9:49 am
*taps foot impatiently*
Thu Mar 03, 2011 10:01 am
Post
ITS ALIVE!!!! :huzzah: :dastardly: :panic: :panic: :panic: :panic: :panic: :panic: :isay: :panic: :panic: :panic: :panic: :panic: :panic: :panic: :panic: :panic: :panic: :panic: :panic: :panic: :panic: :panic: :panic:
Thu Mar 03, 2011 11:22 am
Ok initial overjoy is down...
Its noise free, doesn't do any weird feedback thingy, loud, and overall just awesome... Clean sounds great and break up at 3 o'clock, OD channel sounds good but I haven't tweaked it into perfection yet... clipz when i repair my computer :cop:
http://i274.photobucket.com/albums/jj26 ... C_0575.jpg
Thu Mar 03, 2011 12:07 pm
Fucking fantastic knope! Good job!
:dance: :dance: :dance: :dance: :dance: :dance: :dance:
Thu Mar 03, 2011 12:21 pm
Sweet work man!
Thu Mar 03, 2011 3:05 pm
Oh what OT primary did you use again?
If that PX I have is from an AC15 then I only have a pitiful 91mA to play with if its anything like the AC15 hammond drop in.
It does seem awfully large for such a shitty rating though. It's much larger than the PX I'm using for my buddies 20W amp and that runs about 160mA at about 360V after rectification off the top of my head.
I'm possibly looking at strapping two 0-35,0-35 160VA toroidals together with a voltage doubler. That should get me about 400V no load and probably enough current to run EL34s/KT77s :D I'd need another tranny for the heaters though. The OT I have has 3.25 and 4 K taps but i can double up if necessary. Its not like I'm likely to ever use a 4 ohm tap.
Edit:
Quick tab packet calculation:
Imax = (160/70)*0.5/(sqrt(2))*0.6 ~ 480mA
Win.
Hell I could run 6550s with that :poop:
Fri Mar 04, 2011 7:39 am
Edit:
Win.
My OT is 6.6k. Your plans sound like the ultimate bastard amp of all time :cop: :huzzah:
Fri Mar 04, 2011 6:58 pm
With those trannies 6550s would give 80w into 3k25 with 400 plate and 300 screen. I can see no reason to not do this.
Fri Mar 04, 2011 8:07 pm
Zozobra wrote:
With those trannies 6550s would give 80w into 3k25 with 400 plate and 300 screen. I can see no reason to do this.
Sorry I didn't read it right, kinda seemed extra complicated having 3 power transformers but its definitely doable. And by definitely doable I mean you should do it!!!! :eyebrows:
Fri Mar 04, 2011 9:41 pm
So knope, how are you enjoying your victory over the electrons?
What are your thoughts on the Hotcat?
Fri Mar 04, 2011 9:43 pm
The clean channel is nice but it has just a tad too much bass to my liking... probably my first mod :idea: It breaks up at 2-3 O'clock, and at that point I'm pretty sure its begging me for a treble booster :mwahaha: I'm setting the brilliance knob to my liking on the clean channel.
The gain channel thick yet articulate... MUCH thinker then my Carvin and quite a bit darker yet I can still play bigger chords and the notes don't get drowned out. Its a bit tough to dial in at first but I think I'm getting a hang of it. You need to balance the gain and level knobs, then the edge, bass and treble. Master knob makes it just sound better. Bass and treble seem become low/high pass filters past half way, so if I have both past 12 O'clock I start cutting the mids. Cleans up from thick od to crunch quite nicely.
OR I dime the Master and use the level as volume and its also really awesome, but in a different kinda way. More of a Marshally type response I guess.
Overall Im really happy with this build :tu:
Fri Mar 04, 2011 10:49 pm
I am thinking that the clean channel shouldn't be particularly dark/bassy?
Are you A+ 100% sure that all of your cap values are right there? Might you have a 0.015uF cap off the V1 plate, instead of the 0.0015uF on the schematic? Or similarly a 0.1uF cap for the P.I. input rather than the 0.01uF on the schematic?
It just seems to me that with that 180pf across the volume and the cap values indicated on the schematic, that channel should actually be a bit bright/sparkley, not too bassy?
I still haven't played a real one yet, so perhaps one who has(Snaxo?) can confirm or deny this...? :idk:
Fri Mar 04, 2011 11:24 pm
