| So I own a Blackheart Handsome Devil http://maplifiers.net/forum/viewtopic.php?f=7&t=1262 |
| Author: | Say Ocean [ Sat Feb 05, 2011 10:16 pm ] |
| Post subject: | So I own a Blackheart Handsome Devil |
a) This kicks the shit out of my classic 30 in terms of distortion... it sounds a lot more realistic and less gooby, the only word I can think of to describe the classic 30 b) cleans are meh, but what can you expect from something that costs $200 used c) it sounds good quiet but can get pretty fucking loud basically sg->blackheart is a great dormroom practicing/jamming/ recording set up, can't wait until my pedals from home get here If you need a small portable cheap amp, definitely look into this the hype as 90% true
| Author: | Devtron [ Sat Feb 05, 2011 10:18 pm ] |
| Post subject: | Re: So I own a Blackheart Handsome Devil |
Are those the 30 watt ones? I was looking at those a while back but never pulled the trigger. Glad I didn't now because the Orange TT fell into my lap, but they really aren't the same thing. |
| Author: | Say Ocean [ Sat Feb 05, 2011 10:20 pm ] |
Mine is switchable between 7 and 15 watts Yeah I woulda dug a TT but there was just no way I was finding one this cheap nearby
| Author: | Devtron [ Sun Feb 06, 2011 1:49 am ] | |||||||||
| Post subject: | Re: So I own a Blackheart Handsome Devil | |||||||||
Ah. Well. That's pretty damn cool. CLIPZ. |
| Author: | Say Ocean [ Sun Feb 06, 2011 4:52 am ] |
Soon.
| Author: | chris_d [ Sun Feb 06, 2011 11:50 am ] |
Whoah. I hadn't really noticed that map. The schematic almost looks like a Matchless Spitfire with a different tonestack. I will have to look at it closer when i am not sick and my brain is working again. But it looks like Crate did good with that one. Looking forward to clips. Also: the Atlas EP
| Author: | chris_d [ Sun Feb 06, 2011 12:07 pm ] |
Actually, on second look, it is closer to a Matchless Lightning, but with the cathode follower stage removed and just a plate-driven tonestack wired kind of marshally instead. There are some other changes throughout, but the basic structure is quite reminiscent of the matchless.
| Author: | Devtron [ Sun Feb 06, 2011 12:12 pm ] | |||||||||
Ah, now I remember. This one: http://www.americanmusical.com/Item--i- ... dium=feed& Has the 30w A/Triode mode, as well as the 60w A/Pentode, 50w AB/Triode and 100w AB/Pentode modes. I am still looking for a good deal on a used one. I want to mess around with it, because I have the sneaking suspicion it might not work as well as advertised. If it does though, it wouldn't hurt to have on top of another 2x12. But really, I don't need another amp. I might take one of these guys though for the right price. |
| Author: | chris_d [ Sun Feb 06, 2011 12:17 pm ] |
Aside from the fact that it follows in the Crate tradition of way oversized 100w heads, that one sounds pretty solid: I would probably lean towards the simpler map myself tho. |
| Author: | Devtron [ Sun Feb 06, 2011 12:25 pm ] | |||||||||
I could have sworn they did a model with just either 30/15 or 60/30 settings that was single channel and simpler, but I think I was trippin balls or thinking of something else cause I can't find shit on it. I would rather have that. I most likely wouldn't use half the settings of that amp. But yeah, listening to a lot of clips these are not bad amps at all. I got to play with the little Ant or whatever in the shop, it was cool but I only got to do guitar store browsing playing so I can't say much about it. I was/have been really skeptical when/since they came out, but now that clips and such are floating around more commonly I am a bit more interested. Sadly, my big map slot is (soon to be) filled, same goes for my little amp needs. I certainly don't need another loud ass tube amp either, considering I can barely turn the TT through a Hellatone 30 up past 7 'o clock before it gets too loud. |
| Author: | Say Ocean [ Sun Feb 06, 2011 11:04 pm ] | |||||||||
Next time I go home I'll probably throw the guitars on it and mix it. Have material for a second one too, and I'm writing an EP for a 4 piece with vocals which will hopefully be done by summer. Also have been writing a piano 'n drums EP with vocals, and have a couple other projects in the works. So I should be spitting out a ton of material in the next 6 months or so John just got his ACL replaced (skiing accident |
| Author: | chris_d [ Sun Feb 06, 2011 11:12 pm ] | |||||||||
Aside from the bit regarding the continuing fragility of you Alaskaners, all of those things sound: doap. |
| Author: | Unstrung [ Mon Feb 07, 2011 12:57 am ] |
Alaskans...
| Author: | Devtron [ Mon Feb 07, 2011 10:06 am ] |
John is the reason we can't have nice things like healthcare in America. |
| Author: | torgeot [ Tue Feb 08, 2011 8:59 am ] | ||||||||||||||||||
| Post subject: | Re: So I own a Blackheart Handsome Devil | ||||||||||||||||||
Eggsactly. Maybe karma is getting you Alaskanians for clubbing all those seals.
