| Have you guys heard of these? http://maplifiers.net/forum/viewtopic.php?f=7&t=1282 |
| Author: | Unstrung [ Thu Feb 10, 2011 9:10 pm ] |
| Post subject: | Have you guys heard of these? |
I wanted to post it on the Effects section but no, it's a goddamn amp. |
| Author: | chris_d [ Thu Feb 10, 2011 9:15 pm ] |
| Post subject: | Re: Have you guys heard of these? |
Yarr. I want the .44, but they are moar money than i want to spend on them. But srs, a couple of pedals and a .44, plus a 2x12 cab. Quicky weirdo rig. I dig it. |
| Author: | Unstrung [ Thu Feb 10, 2011 9:25 pm ] |
Indeedydeed! I wonder how it would handle an MT-2...
| Author: | Devtron [ Thu Feb 10, 2011 9:37 pm ] |
Yus and the things I have heard about them are purty good. Edit: However, have you seen the power supply for them? Almost as big as the pedal itself. |
| Author: | chris_d [ Thu Feb 10, 2011 9:37 pm ] | |||||||||
| Post subject: | Re: Have you guys heard of these? | |||||||||
Probably badly. But i was thinking that basically it sounds not too different from how i set up my ghettocrate practice map when i run the timmy into it for doing demos and shizz. For that sort of lighter dirt, i think it might just work well enough. I don't know if it would have enough headroom to deal with the uberfuzz of the MT-2 without losing definition though. And i mean, at drummer volumes. For quieter stuff, i bet it would be doap. |
| Author: | Snaxocaster [ Fri Feb 11, 2011 1:43 pm ] |
I kinda want one just to have.
| Author: | chris_d [ Fri Feb 11, 2011 1:49 pm ] | |||||||||
What i saw looked a bit like a regular wall wart? |
| Author: | torgeot [ Fri Feb 11, 2011 2:11 pm ] |
ok I remember seeing this and wanted to check it out, but gat dayum, a backup amp that fit's in your pocket.
| Author: | Devtron [ Fri Feb 11, 2011 5:02 pm ] | ||||||||||||||||||
| Post subject: | Re: Have you guys heard of these? | ||||||||||||||||||
Maybe I am thinking of something else ... ![]() Or maybe not. |
| Author: | Devtron [ Fri Feb 11, 2011 5:05 pm ] |
That is to say, I am not sure if that is even the power supply for that thing, just the picture I remember seeing. Maybe it was for teh lulz. |
| Author: | Snaxocaster [ Fri Feb 11, 2011 7:51 pm ] |
Aren't those in the EH Nano enclosures? Those are smaller than a Boss pedal, so even with a power supply bigger than the thing itself, that's not very large. |
| Author: | Devtron [ Fri Feb 11, 2011 8:19 pm ] | |||||||||
If not the Nanos, a not-much-larger enclosure. I just think the picture is funny. |
| Author: | Tussy Hole [ Fri Feb 18, 2011 2:59 pm ] |
That pic of the .44 mag and power supply is real; I'm the one who took it. Anywayzs, the mag .44 is loud as hell but doesn't sound that good IMO. Running my tube amp preamp sections into it was noticeably muddier than using tube power. |
| Author: | Devtron [ Fri Feb 18, 2011 7:09 pm ] | |||||||||
Goddamnit I keep forgetting you over there is also you over here. AND WE EVEN SHARE A NAME. |
| Author: | Tussy Hole [ Fri Feb 18, 2011 7:54 pm ] | ||||||||||||||||||
