View unanswered posts | View active topics It is currently Mon Sep 21, 2026 3:09 pm
Reply to topic  [ 11 posts ]
The bestest Marshall eva
Post The bestest Marshall eva
is the one in the pic below, I used it for the past 2 gigs, can you figure out which one it is???
Wed Aug 22, 2012 12:20 pm
Post Re: The bestest Marshall eva
also, not a bad crowd...
Wed Aug 22, 2012 12:22 pm
Is that a new shell/actualmarshallshell, or did you just flip the shivashell and pop the logo on and the feets on the otherside?
Pretty derned sweet.
Wed Aug 22, 2012 12:29 pm
motherfuck... you got it on the first try.
Well I ended up selling the 6100, bought a Shiva head (this is an older Silver one) took the faceplate off, cut new wood, Tolexed it got the gold piping, switched feets. The feet are actually attached using the chassis mount screws.Flipped that bitch over.
"Slash" was amazed. He uses a Soldano and does have a Shive 20th, but said that it's the best sounding Marshall he's heard.
Wed Aug 22, 2012 12:40 pm
on the plus side (I've not seen a bad side yet) now I haz 2 Shiva's. One combo, one head. Also one older, one newer.
Wed Aug 22, 2012 12:41 pm
That is fucking awesome. :huzzah:
Wed Aug 22, 2012 12:50 pm
Whenever I has means to afford a classy map, I'll probably snag a Shiva.
They has sex.
Wed Aug 22, 2012 12:55 pm
Yes. That is, actually, the bestest Marshall ever. (Certainly, the sound I tried to get out of Marshalls for a good long time.)
Also, you have two Shivas. (Shivae?) :huzzah:
Wed Aug 22, 2012 12:58 pm
Shivii?
Edit: also a usable clean channel, not too many Marshall had such
Wed Aug 22, 2012 12:59 pm
If we're treating the a in Shiva as the Latin singular feminine ending, the plural would be Shivae; for Shivi the singular would have to be Shivus. Depends on the case, though; it could just as well be Shivas, Shivis or Shivarum in context.
And yeah, the clean channel actually sounds like a proper clean map. Though I've heard the 6100s aren't bad, and you would know?
Wed Aug 22, 2012 1:10 pm
6100 is the best clean on a Marshall that I've experienced, but still not anywhere near the Shiva clean.
I concur, Shivae it shall be. :deadhorse:
Wed Aug 22, 2012 1:17 pm
