View unanswered posts | View active topics It is currently Wed May 22, 2024 5:46 am
Reply to topic  [ 15 posts ]
Mm, cunty
Post Mm, cunty
Fri Jan 14, 2011 12:07 am
Post Re: Mm, cunty
Is that a new Metasonix pedal?
Fri Jan 14, 2011 6:06 am
Post Re: Mm, cunty
:dukes:
Fri Jan 14, 2011 10:28 am
Post Re: Mm, cunty
Seems useless.... I mean useful, very useful
:dick:
Sat Jan 15, 2011 4:12 pm
Post Re: Mm, cunty
What the fux? :dukes:
Sat Jan 15, 2011 4:26 pm
Post Re: Mm, cunty
Definitely Metasonix. Looks like maybe a limited run (moar tubes?) version of the TX-2?
That is definitely a manufacturer that i do not quite "get".
Sat Jan 15, 2011 4:29 pm
Post Re: Mm, cunty
Though: i am all for the labeling of controls that they are using here. Best thing about the pedal.
Sat Jan 15, 2011 4:32 pm
Post Re: Mm, cunty
Definitely Metasonix. Looks like maybe a limited run (plus tubes) version of the TX-2?
It says "Metasonix" up top, if you look closely. I took a closer look.
I almost think they should have labeled the I/Os merely as "hole".
Sat Jan 15, 2011 4:37 pm
Post Re: Mm, cunty
True that.
It would also be more in keeping with their supposed M.O., as described on the back of the pedal:
Sat Jan 15, 2011 4:40 pm
Post Re: Mm, cunty
Also:
http://www.zerosuminertia.com/audio/metasonix/tx3/
Kind of blah?
Sat Jan 15, 2011 4:43 pm
Post Re: Mm, cunty
I need to get some Metasonix stuffs.
Sun Jan 16, 2011 9:40 pm
Post Re: Mm, cunty
But why?
Just the shock value of the devices, or do you hear something you like in there?
Do i remember correctly that you didn't like the Fuzz Factory because it was bright/thin/flat? That is definitely how the Metasonix stuff strikes me, listening to the clips. :idk:
Sun Jan 16, 2011 9:48 pm
Post Re: Mm, cunty
I've liked what I've heard from the KV-100. Also, just to try it in person, since as of yet, I've not.
Sun Jan 16, 2011 10:49 pm
Post Re: Mm, cunty
Well when/if you get one, i will be curious to hear how you find it. :huzzah:
Sun Jan 16, 2011 11:19 pm
Post Re: Mm, cunty
IIRC, Mr. Reznor is a big fan of the Metasonix stuff.
Sun Jan 16, 2011 11:37 pm
