| Mm, cunty http://maplifiers.net/forum/viewtopic.php?f=8&t=1173 |
| Author: | Unstrung [ Fri Jan 14, 2011 12:07 am ] |
| Post subject: | Mm, cunty |
| Author: | Sardocasm [ Fri Jan 14, 2011 6:06 am ] |
| Post subject: | Re: Mm, cunty |
Is that a new Metasonix pedal? |
| Author: | torgeot [ Fri Jan 14, 2011 10:28 am ] |
| Author: | GnarlySheen [ Sat Jan 15, 2011 4:12 pm ] |
Seems useless.... I mean useful, very useful
| Author: | Snaxocaster [ Sat Jan 15, 2011 4:26 pm ] |
What the fux?
| Author: | chris_d [ Sat Jan 15, 2011 4:29 pm ] |
Definitely Metasonix. Looks like maybe a limited run (moar tubes?) version of the TX-2? That is definitely a manufacturer that i do not quite "get". |
| Author: | chris_d [ Sat Jan 15, 2011 4:32 pm ] |
Though: i am all for the labeling of controls that they are using here. Best thing about the pedal. |
| Author: | Snaxocaster [ Sat Jan 15, 2011 4:37 pm ] | |||||||||
| Post subject: | Re: Mm, cunty | |||||||||
It says "Metasonix" up top, if you look closely. I took a closer look. I almost think they should have labeled the I/Os merely as "hole". |
| Author: | chris_d [ Sat Jan 15, 2011 4:40 pm ] | |||||||||
True that. It would also be more in keeping with their supposed M.O., as described on the back of the pedal:
| Author: | chris_d [ Sat Jan 15, 2011 4:43 pm ] |
Also: http://www.zerosuminertia.com/audio/metasonix/tx3/ Kind of blah? |
| Author: | Sardocasm [ Sun Jan 16, 2011 9:40 pm ] |
I need to get some Metasonix stuffs. |
| Author: | chris_d [ Sun Jan 16, 2011 9:48 pm ] | |||||||||
But why? Just the shock value of the devices, or do you hear something you like in there? Do i remember correctly that you didn't like the Fuzz Factory because it was bright/thin/flat? That is definitely how the Metasonix stuff strikes me, listening to the clips.
| Author: | Sardocasm [ Sun Jan 16, 2011 10:49 pm ] |
I've liked what I've heard from the KV-100. Also, just to try it in person, since as of yet, I've not. |
| Author: | chris_d [ Sun Jan 16, 2011 11:19 pm ] |
Well when/if you get one, i will be curious to hear how you find it.
| Author: | Broseidon [ Sun Jan 16, 2011 11:37 pm ] |
IIRC, Mr. Reznor is a big fan of the Metasonix stuff. |
