View unanswered posts | View active topics It is currently Sun May 05, 2024 12:52 pm
Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Geoffrey, Zozo, and/or whoever, regarding the Boss HM-2...
Post Re: Geoffrey, Zozo, and/or whoever, regarding the Boss HM-2.
Turns out these are hard to get over here. Bugger.
Thu Mar 01, 2012 9:28 am
I will ship one if you want. Though, by then the cost would not be very... efficient.
Sat Mar 03, 2012 8:12 pm
HM-2's go on ebay for 30-40 quid here anyway so I might just wait for a cheap one to turn up. Nick over on HCFX is doing a run of PCBs with a mids pot on so I might pick one up to tinker with.
Thu Mar 08, 2012 7:32 am
I was at the guitar store near my house today and they had an HM-2 for forty bucks. I may go acquire an HM-2 tomorrow. :nods:
Sun Jul 15, 2012 8:09 pm
You probably should.
You know, all the rhythm guitars for Vesication are recorded, and they are all layered 5150 and HM2. I could make an HM2 only mix. It is fucking gnar sounding when I solo the HM2, but my guitarists still want to sound like themselves.
Sun Jul 15, 2012 9:23 pm
You totally should.
Sun Jul 15, 2012 9:31 pm
Well, I have an HM-2 now.
It's rather unpleasant sounding. The low EQ takes it from super-thin to wooly mess, and the "high" EQ seems to be centered around 1k. :lol: Preposterous amounts of gain. And yes, if you turn the low and high controls up all the way, it makes even a Tele into an AC30 sound like Entombed. :hypno:
So yeah, this'll wind up on my board so I can relieve my Geiger Counter of uglyfuzz duties and have it go back to making broken robot noises like it should.
Also, I'm going to give this a spin on bass in a bit, as I brought it home with me for the evening.
Mon Jul 16, 2012 9:13 pm
YESSSSS.
Mon Jul 16, 2012 10:20 pm
Oh, and the "Low" control is centered around 87hz.
The "High" one is actually two bands on one control: one centered around 1300hz and the other around 960hz.
The EQ section boosting those three places has a massive bit to do with the Swedish Death Metal sound. There is some slightly funky clipping in there too, but the EQ is huge.
Mon Jul 16, 2012 10:27 pm
Hah, so I was kinda right re: the "high" EQ. :lol: It is a thickass slab of midrange, that. Both controls full up is very much "that sound"; it's rather hard to mistake for anything else.
Here's a bit on bass. J-bass with EMGs tuned to C# standard with rather dead strings --> Sansamp Bass Driver DI. Sansamp controls are the same throughout: level 10:00, blend noon, treble 3:00, bass 2:00, presence 12:30, drive 12:00.
http://dl.dropbox.com/u/13184331/Bass_HM2_Test.mp3
First bit is clean, second bit has the HM-2 with the level @ noon, both EQ knobs full up, gain around 10:00-ish. The second has a somewhat more usable tone with the level and bass around 1:00, treble around 11:00 and the gain in the same place.
Mon Jul 16, 2012 11:27 pm
Fantastiswell. :huzzah:
Glorious yuckfuzz.
Mon Jul 16, 2012 11:33 pm
When you mentioned funky clipping, were you referring to the EQ section? 'Cause at least on bass, turning up the EQ seems like it's overloading something a bit; it's a bit more controllable with the EQ backed off and seems less gainy- slightly, or at least less clipping into even more clipping- that way.
Mon Jul 16, 2012 11:38 pm
You could very well be hearing the EQ boost smashing into its opamp some(lots) and clipping.
The clipping i was talkin' 'boot is an array that shows up somewhat frequently in various Boss heavy distortions. It is pre-EQ, a combination of germanium diodes in series with the signal plus standard silicon hard clipping to ground. It does kind of a terrible grind-squash thing. That bit has a fair amount to do with why it sounds fuzzlike. And it does lend an element to the "molten lava" grindy thing that Cam mentioned.
In combination with the capable-of-quite-excessive-boost-amounts built into the EQ, you get: violence.
Mon Jul 16, 2012 11:47 pm
Innerestin'. Pushing the EQ does seem to make it go "I cannae clip no more, Cap'n! I'm clipping as hard as I can!" :snax: Which other Boss pedals have a similar thing going on? It actually reminds me a bit, at less extreme settings, of a DS-1, but less shitty. Or, at least, a better flavor of shitty. It doesn't really sound like a Metal Zone at all to me.
Mon Jul 16, 2012 11:56 pm
It does do something related to the DS1, in that it seems to be capable of hitting the rails of its powersupply. Which is roughly/kindof when the signal being transmitted is essentially of a higher voltage than the power supply can swing to reproduce. The DS1 is extra horrible for sounding like that, and it is one of the things that i hate the most about that pedal.
I agree that the HM-2 seems much less horrible about it all. In the HM2 it comes across as more of a compressionviolence to me than as a clearly incorrect design decision. I actually think that the funky germanium/silicon clipping is likely there largely to reign in this very sort of thing.
As far as other pedals that do similar-to-HM2 stuff, i don't know that there really are any. I do kind of consider it an iconic sort of fuzz sound all its own. There are other pedals that i have seen the same clipping section in(though my brain is sleepy right now and stubborn i suppose, doesn't seem to care to recall them. But i have seen it several times in various pedlols.).
Tue Jul 17, 2012 12:12 am
An interesting observation I made with mine, when I dialed in a good tone with a moderately charged battery, switching to an AC adapter engaged ultra death blast mode. Like the sound coming out was indecipherable.
When I go home I'll do one of the HM2 mixes.
I could do it today as I'm not working, but I don't fucking feel like it. I'll just stay here and solder all day. :red:
Tue Jul 17, 2012 9:24 am
I have an old 70's Ross phaser that sounds perfect with a battery, finest phaser tones ever, Put and AC adapter either with a 9v battery adapter or the little miniplug and it loses all victory.
Tue Jul 17, 2012 10:30 am
I forgot to mention but about 6-7 months ago I acquired an HM-2 in a fit of drunken madness crossed with ebay. It sounds like total dog shit run into a laney. I've yet to try it with my superbass but I'm trying to not get too attached to that amp as I want to sell it so I can put the cash money into building new toys and repairing my AOR.
Wed Nov 14, 2012 9:40 pm
I seem to have had the best luck with it into the cleanest of cleans.
It sounded like nothing too great going into my Laney either.
I done seen a guy on youtube sounding awesome with it into his 5150 though.
Thu Nov 15, 2012 12:58 am
I'm using a GH100TI which has some pretty extreme voicing and early cold clipping stages which I guess it doesnt play well with. The input stage of the low input is a 10k cold clipper so boosting it with something like the HM-2 is going to produce all sorts of wacky dirt tones.
Thu Nov 15, 2012 8:12 am
