View unanswered posts | View active topics It is currently Mon May 20, 2024 2:46 pm
Reply to topic  [ 9 posts ]
OK hit me up with ideas
Post OK hit me up with ideas
MY '77 LP has very old Overlend Actives (EMG before they were called EMG) innit. Minihum size, quite rare, but I don't use this guitar because I get a lot of drive out of the amp and dirt box so the active pups just muddy it up and I am truly not a fan of actives. I am not routing it (it's a deluxe) so I am thinking of a P90 in the neck and a Minihum in the bridge. Gives me some wiring ideas, I will replace all the pots etc when I do this, I will most likely use GFS pups unless I hear of something that will really get me off from you guys. So give me pup ideas as well.
Tue Jan 11, 2011 10:57 am
Post Re: OK hit me up with ideas
2x90s wired up 50s style would be my choice, having just done it on my Gibson - sounds snaxcellent :love:
Tue Jan 11, 2011 3:08 pm
shredder
Here's the seymour duncan site on pickup wiring...
http://www.seymourduncan.com/support/wiring-diagrams/
There is a P-90 Stack under Other Wiring Diagrams. Maybe you can get some ideas from this....
I also would consider the fullbore switch. This will bypass all pots and caps and hook your pickup directly to your amp. It's must have for me! YAH!
Wed Jan 12, 2011 10:01 pm
This is badass.
Wed Jan 12, 2011 10:05 pm
This does not surprise me from you at all. Brootal motherfucker live :rawk:
Thu Jan 13, 2011 9:55 am
I like this.
Thu Jan 13, 2011 5:16 pm
shredder
I finally found where the fullbore circuit is... http://www.1728.com/guitar4.htm
Yeah i know it's really called a "Guitar Solo Switch" but that sounds boring, doesn't it?
Thu Jan 13, 2011 7:20 pm
shredder
I forgot to mention I use the pull switch pots or whatever you call em. It has the switch on the back of the pot so you don't have to do any drilling on your axe!
I would suggest, 2 phase switches, 1 series/parallel switch and 1 fullbore switch.
Wire the phase switches to the tone pots.
Wire the series/parallel switch to the neck volume pot.
Wire the fullbore switch to the bridge volume pot.
This would give you lots of tones, plus the fb switch when someone tells you turn it down! hahahahaha
Thu Jan 13, 2011 7:35 pm
hmmm, I may have to drop this off to you :nods:
Thu Jan 13, 2011 8:49 pm
