View unanswered posts | View active topics It is currently Mon Sep 21, 2026 1:31 pm
Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
I love blurry cellphone pics! (Knope's Hot Cat Build Thread)
Post Re: I love blurry cellphone pics! (Knope's Hot Cat Build Thr
My Hot Cat wasn't dark/bassy at all on the clean channel. It could get downright harsh if you weren't careful with the brilliance.
Sat Mar 05, 2011 1:19 am
I am thinking that the clean channel shouldn't be particularly dark/bassy?
Are you A+ 100% sure that all of your cap values are right there? Might you have a 0.015uF cap off the V1 plate, instead of the 0.0015uF on the schematic? Or similarly a 0.1uF cap for the P.I. input rather than the 0.01uF on the schematic?
It just seems to me that with that 180pf across the volume and the cap values indicated on the schematic, that channel should actually be a bit bright/sparkley, not too bassy?
I still haven't played a real one yet, so perhaps one who has(Snaxo?) can confirm or deny this...? :idk:
I'll have to check tomorrow then. The clean top end is pretty sparkley and bright, it just seems to have a tad bit more bass then what I would like.
Sat Mar 05, 2011 1:20 am
Also, congrats on the build. It looks nifty. Those are great maps.
Sat Mar 05, 2011 1:23 am
Thanks! Does my description of the gain side sound like the Hot Cat you had?
Sat Mar 05, 2011 1:25 am
knope wrote:
Zozobra wrote:
With those trannies 6550s would give 80w into 3k25 with 400 plate and 300 screen. I can see no reason to do this.
Sorry I didn't read it right, kinda seemed extra complicated having 3 power transformers but its definitely doable. And by definitely doable I mean you should do it!!!! :eyebrows:
fo'rilla.
They all stack on top of each other so its not taking up a great deal of real estate and then all the secondaries are wired in series for the B+. Not the neatest solution but £30 for a 400VDC 480mA transfomer makes me not too worried.
The same company sells 0-35,0-35 trannies with 300VA and 500VA cores so if I dig the sound of 6550s at that plate voltage then I can get pretty much 1A of B+ to run 4 of them for not much monies :isay:
Sat Mar 05, 2011 6:08 am
All the cap values check out so :idk:
Might be my speakers though :cop:
Sat Mar 05, 2011 4:23 pm
The description of the gain channel sounds about right. The speakers could definitely be the culprit. Those Hot Cats are basically made for V30 speakers.
Sat Mar 05, 2011 8:45 pm
Noted... Greenbacks should also work well right?
Sun Mar 06, 2011 6:12 pm
Noted... Greenbacks should also work well right? MAYBE K100s?
PS. I don't care what you have to do to make it happen...
BUT THIS THREAD NEEDS CLIPS.
Tue Mar 08, 2011 11:45 am
CLIPS NAO BISH!
Tue Mar 08, 2011 12:46 pm
Just out of interest, what is the plate voltage under heavy load if you happened to have measured it?
Wed Apr 13, 2011 6:45 pm
I don't have it as I really don't trust my multimeter to handle large amounts of voltage/current :facepalm:
That would be checking the voltage with one side of the multimeter on the plate and the other side on ground?
Wed Apr 13, 2011 7:19 pm
Yup, the plate to ground voltage would be fine!
I guess it runs at about 400VDC with not much load?
Thu Apr 14, 2011 4:18 am
Late as I just got the balls to poke my MM in my amp. (All the voltages checked out great :nods: )
I have 398v on the plates with no signal.
Fri May 20, 2011 8:58 am
Interesting stuff thanks. Thats the sort of ballpark figure I can get from a 0-35,0-35 VAC toroid run into a voltage quadrupler :rawk:
Sun May 22, 2011 6:01 pm
shredder
Probe with one hand. Your other hand should be behind your back not touching anything. Get zapped and you may be doing this.... :mexican:
Mon May 23, 2011 5:47 pm
This! I spent a month an a half reading on tube map safety before I even bought the chassis. FUCK YOU 400v! :dukes:
Tue May 24, 2011 1:00 am
I had a little taste of 400V a month or so ago. It wasnt the worst thing ever but I dont fancy doing it again.
Tue May 24, 2011 1:24 pm
I could run my amp at 16ohms with my 8ohm cab right? 6.6k would become 3.3k which is still plenty for a pair of EL34s right?
Sun Dec 11, 2011 12:57 pm
