View unanswered posts | View active topics It is currently Sun Aug 30, 2026 8:55 pm
Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3  Next
Room Micing Test
shredder
Post Re: Room Micing Test
I read about getting mics in phase awhile back. I can't find the link. But what I have been doing is setup the mics, get the proper level. Then let's say fader1 goes to mic1 and fader2 goes to mic2. Pull fader2 down all the way. Play and push fader2 up and watch your stereo bus meters. If when applying fader2 both meters continue to rise then the mics are in phase with each other. If the meters start to dip when fader2 is being applied than the mics aren't in phase. I have also cheated and have gone back to the recorded wavs and nudged one wav to try and match up the peaks with the other wav.
Sorry, you might already know all this but thought I'd mention it because the mics in the first recording could of been slightly out of phase with each other. The second recording sounded so robust, I'm thinking all the mics were in phase. I could be wrong as usual.
Great sounds anyway!
Wed Jul 06, 2011 7:36 pm
Trust me, as per evidence from my previous recording posts, I don't know much.
This sounds like a sensible trick I should try though.
Wed Jul 06, 2011 8:04 pm
http://soundcloud.com/devin-currie/riot ... _ldc-close
Put the OM2 off axis.
Also, this and the last clip were both recorded with the strat neck pickup with the tone knob rolled almost completely off ... not intentionally but the results were fine enough.
Wed Jul 06, 2011 10:22 pm
NOW WITH MORE SM57:
http://soundcloud.com/devin-currie/riot ... 57-and-990
Thu Jul 07, 2011 6:18 pm
So far, my favorite is the second clip, the 990 on the grill and the OM-2 back and on-axis. That may change in a mix or with you playing around with the 57 more.
Thu Jul 07, 2011 7:46 pm
Question:
Where do you guys usually put your 57's?
Thu Jul 07, 2011 8:00 pm
I usually have mine aimed in between the dust cap and the edge of the cone. YMMV.
Thu Jul 07, 2011 8:03 pm
This, usually at a 45º angle, an inch or two back.
Thu Jul 07, 2011 8:13 pm
Pretty much.
Thu Jul 07, 2011 8:36 pm
Messed around with the 57.
http://soundcloud.com/devin-currie/riot ... nd990take2
Thu Jul 07, 2011 8:49 pm
Pretty much.
If whatever else doesn't work, try this. If this doesn't work, turn the knobs. If that doesn't work, the problem is probably somewhere between the guitar and the strap.
Thu Jul 07, 2011 8:54 pm
Fuller sounding, with nicer top end, too. :tu: Clearer in the lows than #2, I think, too. Needs drums and bass. :red:
Thu Jul 07, 2011 9:02 pm
That sounds a lot better. And awesome too.
Thu Jul 07, 2011 9:19 pm
Thu Jul 07, 2011 10:42 pm
If I re-recorded this to a click, would anyone want to take a crack at some drummy drums for it?
Sat Jul 09, 2011 9:57 pm
Mayhap. :dildo:
Sat Jul 09, 2011 10:02 pm
I do love to record those drums, but I believe chris' drum vibe is the correct choice for your song. :huzzah:
Sat Jul 09, 2011 10:54 pm
Everyone on the forum should do it IMO, like a reverse drumjam. :idea:
The programmers could program, and the players could play.
Sat Jul 09, 2011 10:56 pm
That's a pretty gnarly idea.
I could play around with the minimal drum micing setups that I find so terribly interesting.
:beer:
Devin... steady speed ahead!
Sat Jul 09, 2011 11:15 pm
I approve of this idea and will have a clicked track Monday.
Sun Jul 10, 2011 12:20 am
