View unanswered posts | View active topics It is currently Fri May 17, 2024 3:37 pm
Reply to topic  [ 17 posts ]
Tell me your vibes
Post Tell me your vibes
Give me some recommendations on a vibe pedal, and a price thereabouts. It's time for me to upgrade, yet I must watch my money spent.
Tue Aug 17, 2010 10:49 am
Post Re: Tell me your vibes
Check out the Danelectro Cool Cat Vibe. I haven't heard or used it, but the rest of the pedals in the Cool Cat line are excellent(and in some cases copies of boutique stuff) and they also go for like $40 new. :idk:
They probably have them in Guitar Center, also.
Tue Aug 17, 2010 11:00 am
Oh. Also, you could check out the Danelectro Chicken Salad.
It is one of the older super cheap mini plastic ones. You can find them for less than $30. Lots of folks like them. The only thing is that the little plastic enclosures are pretty low-fi, and cannot take too much abuse. Lots of nerds rehouse the Chicken Salad in normal metal enclosures with better jacks and true bypass.
But if you just need a ghetto quick solution, you can get the little fuckers real cheap. And for occasional use, they can do just fine.
The Cool Cat ones are a lot more sturdy and nice though, and have proper bypass in them from the getgo. :idk:
Tue Aug 17, 2010 11:06 am
yeah I have one of the Chicken Salads, I actually need to do a vibraphone type thing, a la Cold Shot, (cover band thing) and I hear the Rocky Road is good for that. Has a ramp up/down button too.
I've been actually pretty happy with those little Dano things, but haven't got any of the cool cats yet. I will look into one of those.
Tue Aug 17, 2010 11:40 am
I have been using the Boss tremolo pedal for a while. The simple one, teal with three knobs. It is one of those pedals that I will cuddle and snuggle so lovingly. So cute with the three knobs...
It has a very simple mod (forgot specifics but you basically cut out one capacitor to extend the pedal's range)...
Some clips of it in action:
http://www.soundclick.com/bands/page_so ... ID=9094586 < clean guitar pre-chorus
http://www.soundclick.com/bands/default ... ID=8585955 < pre chorus and bridge... I guess I like it for pre choruses. :red:
Does what you'd expect such a pedal to do, no more and no less. Good enough for me...
Edit: Are you referring to a pedal that wobbles the pitch, and not a tremolo? :poop:
Tue Aug 17, 2010 4:53 pm
I don't think i have heard the lyrical version of that one yet, Geoff. :lol:
Tue Aug 17, 2010 5:11 pm
:D
"Look what I can do when I take my pants off..." (guitar solo)
Tue Aug 17, 2010 7:51 pm
I'm thinking of a Leslie/Vibraphone type effect. I do heart the tremelo's as well.
Wed Aug 18, 2010 10:48 am
Hitachi Magic Wand. :red:
Wed Aug 18, 2010 5:57 pm
Yes, have one of those in my arsenal already sir. And yes it does the spinny thing quite well.
Thu Aug 19, 2010 6:34 pm
How do you plug a guitar into that, anyway? :?
Fri Aug 20, 2010 3:00 am
You need a goat, 3 medium sized paperclips, and some castor oil. Once you have that, let me know.
Fri Aug 20, 2010 11:26 am
The paperclips I have, the oil I can find... Does it have to be a live goat, or will a slab of goat do? I think I can find it at the one MuslimMart.
Fri Aug 20, 2010 5:11 pm
I've only done it with a live goat. Do you have a Scarifices'R'Us nearby? I know there's one in Geneseo....
Mon Aug 23, 2010 8:01 am
There is an adapter for live sheep, if those are more readily available to you.
I also read once you can use a poodle if you tie fake horns to it's head using spider's silk.
Mon Aug 23, 2010 4:24 pm
Unfortunately, I do not have any recommendations other than to stay away from the Fulltone Dejavibe. 'Tis lame. :monocle:
Thu Sep 09, 2010 2:07 am
Well I ended up with a cheap Rocky Road. fun little box it is. There's a boost when it kicks in but there's a real easy mod for that which I will do when I get some time. I will post clips once I get some more of that time....
so now the pedals are arranged as such, TU-2>OCD>Map then the loop is send>CE-3>Phase90>Carbon Copy>Holy Stain>Rocky Road>return I took the Allums SD1 out for a bit, I 'm just out of room on the board. One of the bands is adding Man in the Box to a set so I will need to fake the talkbox with a wah and I have one of the Morley Mini wahs which should fit if I make some room.
Fri Sep 24, 2010 8:05 am
