View unanswered posts | View active topics It is currently Sat May 18, 2024 6:11 pm
Reply to topic  [ 19 posts ]
Whats your toan?
Post Whats your toan?
Im pretty content with mine right now. Guitar > modded od9 > Modded wah face > bbe boosta grande> jsx > G maj in loop.
Sat Aug 21, 2010 7:41 pm
Post Re: Whats your toan?
No OD20?
What happened to JVM bast evar?
Me, either MT-2 > Laney or OD9 / SD-1 > Quick Rod...
Sat Aug 21, 2010 7:49 pm
JVM bast avar is gone. JSX is just as good for half the price plus I like the way it responds to lower fq
No, od20 is still around. The I play the od20 > randall rg at my buddies house but thats my home rig in the op :poop:
Sat Aug 21, 2010 9:56 pm
generally I'm a marshall chick. I like EL34's. but recently because of small clubs and doing lighter cover tunes I am doing either OCD or Allums modded SD-1 into the V22. I was just looking at it today and realized I had it set for Triode mode...... I forgot it had that switch on the back.
Sat Aug 21, 2010 10:48 pm
My noise is basically a bright Voxy amp cranked to about 2:00. I still need to do some speaker testing to see what i like best, but something greenback-ish is definitely workable. I suspect that if i can get my hands on some cheap G12H30s, i will like them more though. I also need to build some different cabs for myself. The ones i have are all too loose and flubby for doing some of the things i need to. But the cranked Voxy thing is the sound i was looking for for many years. I just didn't know to look for it there, for a long time.
As that is not always workable, even with a 20w version of the Voxy amp, my 'most of the time' sound is two or three overdrives stacked for varying degrees of what i would normally be able to get with one boost and my guitar volume knob if i could play normal loud.
Really, though, lately 90% of my playing and demo recording has been withe the same stacked overdrive setup, into the Crate GX15R. It sounds a lot worse, but is just quicker for getting ideas down, at any time of day or night. :red:
I already have super restricted time slots when i can record drums. I need everything else free for guitars, so the guitars have to be quieter. :idk:
Sat Aug 21, 2010 11:02 pm
Your Crate sounds fine enough though. I've never heard it and gone, "ew, bad toan!"
Interestingly there are posters on other forums who own thousand dollar pres, which they swear by, yadda yadda, and their tones have been 'ew' and the clips as mediocre as ever.
Application > $$
Sun Aug 22, 2010 2:48 am
Soon to be Mustang/Tele > Russian Big Muff > Micro POG > Egnater Tweaker.
So excited.
:love:
Sun Aug 22, 2010 3:02 am
I'm pretty content right now
Epi LP or sharpiecaster > dunlop wah > modded sd-1 > muff clone > dd-6 > Carvin x60b
working with 5 sounds
amps clean
amp's dirty channel for a more articulate and cleanable dirt (boosted with sd-1 for leads)
fuzz for thick awesomeness that can be slightly rolled back for a more "normal" dirt sound(also boosted for leads)
wouldn't mind getting the same noise through something voxy/matchlessy/badkittyey :cop:
Sun Aug 22, 2010 3:09 am
Strat or Tele --> NMV AC30, one Blue, one Greenback, channels jumpered, Brilliant volume c.1:30-2:00, Normal volume c.2:00-3:00. Cut control off, Bass around 2:00, Treble around 12:00, IIRC.
Add pedals as necessary.
Sun Aug 22, 2010 5:10 pm
Ibanez EX-1500 with a Duncan JB in the bridge > Maxon OD-808 > 6505, XXX, or JSX > G-flex 212.
I'm an amp whore. I want an E530. :lol:
Sun Aug 22, 2010 7:55 pm
You have all three of those amps in your possession right now?
Sun Aug 22, 2010 8:25 pm
Yes. Just used 2 of them on my Evisceration Plague cover. Plus, I have a now dead Peavey Stereo Chorus 2x12. The preamp still works so I'll keep it for mindless fuckery.
Sun Aug 22, 2010 11:38 pm
Did you do ALL of Evisceration Plague?
Drums and everything?
Sun Aug 22, 2010 11:58 pm
Yeah, I did drums via MIDI. I'm a little over halfway through it... laziness has the best of me. :lol:
What I've got so far is in the Your Recordings section.
Mon Aug 23, 2010 12:02 am
SG or Strat --> Suhr Riot --> Mesa Blue Angel.
Fri Sep 03, 2010 7:06 am
I looked into those Blue Angels back in the day. I ended up buying an Egnater TOL50 instead, but I have always wondered what could have been. :idea:
Fri Sep 03, 2010 10:33 am
I have been using the channel switching on the Bug v22 for dirty/clean tone. I have now for past 2 weeks been just using the clean channel + OCD when I want the dirt, and the SD-1 for a lead boost. I still have the dirty channel but have not been using it.
Oh currrent Pedal board is TU-2>OCD>SD-1>Chicken Salad>Phase90>Carbon Copy>map
Fri Sep 03, 2010 11:38 am
Moist But Firm
Gutierrez Juggernaut (EMG85/60), Mako Makoplex, Hughes and Kettner Access Preamp, T.C. Electronic G-Force, VHT Deliverance 4x12.....various accessories. :rawk:
Fri Sep 03, 2010 8:26 pm
I don't think I actually have a 'toan' specifically... I practice with a pretty unimpressive one, I have large amps that I haven't used recently for anything but recordings, and for recordings I often just use impulses and stuff sometimes to keep the variety...
I do not haz one toan.
But my toanz do tend to have high gainz in common. :unstrung:
Sat Sep 04, 2010 3:46 pm
