View unanswered posts | View active topics It is currently Sun Nov 01, 2026 3:20 pm
Reply to topic  [ 75 posts ]  Go to page Previous  1, 2, 3, 4  Next
Poast things you have built/made
Maplitonian
Post Re: Poast things you have built/made
I'm building a 383 for my camaro right now.
Tue Nov 09, 2010 12:08 am
When it comes to the automotive shit... right now I'm rebuilding a TH400 for a friend and as soon as that's done I've got a Quadrajet to rebuild for my own uses later down the road.
Tue Nov 09, 2010 12:19 am
Maplitonian
Nice man! What do you drive?
Tue Nov 09, 2010 12:36 am
I have an 89 Chevy 1500 right now... Plans for that Quadrajet involve a Monte Carlo or El Camino and a 400 small block that I have laying in the floor of my garage.
Tue Nov 09, 2010 12:58 am
Maplitonian
I have an 86 Z-28 that the 383 is going into. It has a 305 and a built 700r4 in it right now. I'm going to run all forged on the 383, a pretty badass lunati cam, and probably a 150 shot of spray.
Tue Nov 09, 2010 1:40 am
I'm planning to get lots of machine work done on the 400... balanced, blueprinted, lightened, maybe bore it .030 if I'm fortunate enough to have the extra material to bore. It'll be running mostly stock until then, though. It's an early 400, 71 model, so it's still got 10.5:1 compression and shit.
I have a set of the infamous camel hump DZ302 heads that will be going on it, and a lunati .292/.292 duration .488/.488 lift cam that will be going in it prior to installation. I believe it should be rather quick. :)
Tue Nov 09, 2010 1:48 am
Maplitonian
Post Re: Poast things you have built/mhttp://maplifiers.net/forum
Nice! Sounds like a sick build. Since mine will no longer be my daily, I'm looking at this cam. http://www.summitracing.com/parts/LUN-50168SB/
My 305 has a Competion Cam with the same specs as that lunati you're looking at, and it's really not big enough IMO. With the kinda heads your running and work you're putting in, why not run a hotter cam?
Tue Nov 09, 2010 1:59 am
I want a streetable build. With everything being lightened and shit, the engine will make considerably more than with the stock internals. It'll be at about 400hp (rough projection, honestly) but rev super quick and idle lumpy at about 800rpm. That's the goal, anyway. Whether it comes out that good or not is a different story. I usually do all-out builds.
I thought about a higher lift cam, but I'm running dome pistons in this build, so my max is about .500".
Tue Nov 09, 2010 2:14 am
I want to give you guys my dakota so you can put a 427 in it.
Tue Nov 09, 2010 2:19 am
I could probably manage an LS7 swap in it. I doubt a big block would fit in it though. :lol:
Tue Nov 09, 2010 2:20 am
People put in 408s all the time. ls7 would be a fucking dream.
Tue Nov 09, 2010 2:22 am
A 408 is a small block. It's a 360 bored .060 and stroked.
Tue Nov 09, 2010 2:23 am
Maplitonian
A 6.1 hemi swap would be easy for that truck.
Tue Nov 09, 2010 1:34 pm
Yep, since the later incarnations of those trucks came with 4.7s, there would be very little fabrication involved.
Tue Nov 09, 2010 2:00 pm
Maplitonian
I believe Mike's either has the 318 or the 360, since it's a Dakota R/T.
Tue Nov 09, 2010 9:58 pm
Yeah he said his was a 360 at some point.
Wed Nov 10, 2010 7:27 am
First amp build
Current preamp build
Its not finished yet btw so no clips :red:
Wed Nov 10, 2010 4:40 pm
shredder
Fri Nov 12, 2010 7:14 am
Needs sriracha
Fri Nov 12, 2010 7:21 am
What manner of infantile creatures are those? They look like baby rats to me.
Fri Nov 12, 2010 1:34 pm
