View unanswered posts | View active topics It is currently Mon Sep 21, 2026 11:38 pm
Reply to topic  [ 341 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 18  Next
The workbench thread
Post Re: The workbench thread
You could mount it as an internal trimpot, also? :idk:
I hear you though. I considered it for my last amp but ended up leaving it out. I will probably use one in my next build though. Probably stick with the super simple bass/treble vox stack that i love, and add the slope in between them labeled "fucked up mids knob" or something. :red:
Thu Dec 16, 2010 9:56 pm
I like the internal trimpot idea. I'm trying to not have a million panel controls on stuff if I can help it just remove the possibility of dialling it badly for other people as some of the controls are a bit counter intuitive and most people try to dial an amp in with their eyes.
Fri Dec 17, 2010 6:24 am
:isay: :isay:
Mon Dec 20, 2010 6:53 pm
:love: tres bien
Fri Dec 24, 2010 9:53 am
It's not really green though. Thats the drill mask.
Fri Dec 24, 2010 11:58 am
:mad:
needs green
Fri Dec 24, 2010 3:11 pm
not for me so I dunno if he'd be game for that :poop:
Fri Dec 24, 2010 3:45 pm
:panic: :panic: :poop:
Mon Jan 10, 2011 10:24 am
big picture is big
Mon Jan 10, 2011 10:36 am
http://dl.dropbox.com/u/8802910/andy_rev_1.png
:panic:
Just got to source parts now mother bitches.
and do the layout :( ...
Wed Jan 26, 2011 5:49 pm
So the bits are in the mail for this. Should be here from when I return from my adventuring in Walesland.
In other news I converted my preamp to be much more of a higher gain thang. Did away with the switchable boost and added that stage into the lead channel. The layout is a bit messy and stuff is all over the place which hasnt done much for the noise but I was expecting that. The whole thing is a dick about box anyway so fuck it. In a nutshell I borrowed heavily from the Iommi sig laney but didnt have enough stages for the cathode follower to drive the tone stack so I ignored it and put the TS on the plate of the stage before. This thing has serious balls and clarity! I cant get over it. Needs a wee bit of tweaking to get the extreme lows and highs sounding right but its pretty damn close to what I'm after which is a nice and open high gain motherbitch. The amp I'm running it through doesnt have depth or presence controls which would probably dial it in just right. I think I'll use something very similar to this in my war bastard amp when I finally build that.
Wed Feb 16, 2011 3:03 pm
:panic: :snax: :tu: :D
Wed Feb 16, 2011 11:27 pm
Just two parts orders to come now and then this motherfucker is getting built :panic:
Mon Feb 21, 2011 5:36 pm
Drilled out the IEC socket today, going to cut and populate the board on saturday. I'll drill, label and clear coat the chassis on sunday.
:panic:
Thu Mar 03, 2011 3:07 pm
I've just nipped down to my departments workshop to get the board cut to size. I still need to check the PI and filtering layout t make sure I havent been a goon. The board mounting holes arent going to move though so I'm going to drill those out so I can drill the chassis and test fit everything. Then I can label and clear coat the chassis :isay:
Is the layout is golden then I'll populate the board tomorrow and then this sucka should be built by the weekend :panic: :panic:
Tue Mar 08, 2011 7:30 am
Moar mapz iz good!!! :panic: :panic: :panic: :panic:
Tue Mar 08, 2011 9:40 am
I want to build a new map so bad. :dukes:
Tue Mar 08, 2011 11:46 am
:panic: :panic: :panic: :poop: :poop:
This is the first chassis I've drilled. Its a little wonky in places but its nothing a little file work wont fix up.
Tue Mar 08, 2011 3:37 pm
Also there was a goddamn B250K pot missing from my parts order :facepalm:
Oh well... one should arrive by the time I'm ready to fire her up.
Tue Mar 08, 2011 5:11 pm
Drill mask removed :poop:
Wed Mar 09, 2011 2:10 pm
