View unanswered posts | View active topics It is currently Thu Jun 27, 2024 1:53 pm
Reply to topic  [ 341 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 18  Next
The workbench thread
Post Re: The workbench thread
I needz money :mad:
Sun Nov 28, 2010 8:54 pm
knope wrote:
I needz money :mad:
These were almost exactly my first thoughts.
Building maps is goodtimes. :panic: :huzzah: :panic:
Sun Nov 28, 2010 9:41 pm
Zozo, that looks more solid than anything I've owned.
Sun Nov 28, 2010 10:58 pm
Thanks man but I'd reserve judgment until the rats nest inside is installed haha :poop:
This is only my second build but I've spent a lot of time reading and looking at how other people do things. The Heater wiring on this is definitely much better than my first amp turned out. I'm not elevating the heaters on this so Its pretty important that I do a good job of it as there will be a fair bit of gain going on.
If I dont end up going to my friends gig tonight I will wire the pots and sockets up so if there are no cock ups I'll get this sucka built this week!
In other news - I've found a reasonably cheap PX for the jazz/crunch amp I'm thinking of building. 200mA at 350V should give me 420V after rectification and the heaters are good for 5-7A. This means rather then compromising with 5881s I can go straight in with 6L6GC's running at about 40W. I'm probably going to build this in parallel with the 20W amp I'm making for a friend, which will be my first attempt at DC heaters since the torroidal PX has a beefy 9V winding.
Mon Nov 29, 2010 6:16 am
underside and pots wired.
Mon Nov 29, 2010 2:00 pm
I totally wired up the relays last night. Tricky sumnabitches to do. I didnt want to solder direct to the pins so I used some IC sockets and removed the unwanted pins. Tonight I may well get this thing fully assembled*!
* working is a different matter.
Wed Dec 01, 2010 7:08 am
Booze happened, progress didnt.
Wired up the LED's. They're ultrabrite white ones I got from dealextreme ages ago and damn, they are bright as hell - they'll pretty much illuminate a room!
Thu Dec 02, 2010 7:33 am
Thu Dec 02, 2010 2:07 pm
I have ultrabright LED in my Allums modded SD-1. It's so fucking bright I need to put a finger over it to view my settings. How many do you have it that? Prolly looks like a runway
Thu Dec 02, 2010 2:14 pm
one for each channel and one for the boost. will be running at 5v so they might not be too savage.
Thu Dec 02, 2010 2:55 pm
sexy! :panic:
Thu Dec 02, 2010 9:05 pm
Looks like a much simpler version of my Twin inside. :nods:
Fri Dec 03, 2010 8:59 am
Only the input, switches and transformer to wire in now
:panic: :panic: :panic:
Fri Dec 03, 2010 10:29 am
PX is getting wired in tonight :panic:
Tue Dec 07, 2010 7:47 am
:tu:
Tue Dec 07, 2010 9:44 am
And thus the debugging begins
:poop: :wall:
Tue Dec 07, 2010 7:45 pm
Now THAT isn't what we wanted to hear. :red:
I am very lucky to have had all but the very first map i built work on the first go. Actually i got lucky on the first one too, i just forgot to ground the output jack. :red:
FX pedal builds on the other hand, oh about one out of three has needed a stern talking to with a debugimifier. :cop: :poop:
Tue Dec 07, 2010 8:37 pm
Hmm, the plate and cathode voltages look reasonable enough as can be seen here in ghettovision(tm):
http://dl.dropbox.com/u/8802910/voltages.PNG
Tue Dec 07, 2010 8:38 pm
What ails it?
No sound?
or
Bad sound?
Tue Dec 07, 2010 8:42 pm
Very faint signal from the clean and sack all from the lead. At least isnt a self oscillating mess I suppose :poop:
Tue Dec 07, 2010 8:48 pm
