View unanswered posts | View active topics It is currently Mon Aug 31, 2026 11:10 am
Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3
Need some of this sexy shit.
Post Re: Need some of this sexy shit.
They even have, "bottled patinas" ...
Sun Jan 23, 2011 5:31 pm
But no really, i agree, there is something to be said for the regular shiny shiny.
It might be difficult to keep it from going dull then green though, and you might find that clearcoats will want to lift off the surface through seasonal heat/moisture changes.
Would look doap if it worked though.
I am totally into that blue one. I will put it away in my brain hole, and someday perhaps, revisit it with money. :red:
Sun Jan 23, 2011 5:33 pm
http://www.copper.org/resources/propert ... ishes.html
My head asplode.
I figure it would wear faster than a clear coat applied to wood, but the wearing might add a pretty nifty effect over time.
Sun Jan 23, 2011 5:40 pm
http://www.copper.org/resources/properties/protection/clear_finishes.html
My head asplode.
So i guess basically that is saying that pretty much everything will eventually allow the copper to darken, just a matter of how long it will give you. Something that is continually handled like a guitar, sounds like it might be more difficult than other things, to keep shiny.
You could always go with the thinner copper foil and wrap the guitar like these doods do with the aluminum style:
And just replace it if it starts to get ugly.
Though again, i think it is likely to dye your picking arm greenish where it rests on it.
Sun Jan 23, 2011 5:50 pm
No one wants a green arm :cry:
It's a tough choice.
Sun Jan 23, 2011 6:22 pm
Also, Jaguars are sweet. Can you get along wif the short scale Snaxo?
I should actually play one versus ogling them from afar. Really, it depends on the neck profile. The depth is the important factor. I'd rather have a Les Paul neck that's like a baseball bat than a longer scale Jackson or whatever shredder neck that's about 1/16th of an inch thick. The current versions seem to have beefier radii?
Mon Jan 24, 2011 2:32 am
Morrissey
that looks fucking sick, that mandola. I kinda want an electric sitar-guitar too.
Sun Mar 13, 2011 10:29 pm
