View unanswered posts | View active topics It is currently Tue Jul 02, 2024 1:13 am
Reply to topic  [ 341 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 18  Next
The workbench thread
Post Re: The workbench thread
Clear coating went a bit wrong and the front is a bit banged up from when it was bent and my drilling hasnt helped so I think I'm going to paint the front panel black. Ah well.
Wed Mar 09, 2011 8:13 pm
I'm way happier with this than the alu panel :poop: :monocle:
Thu Mar 10, 2011 5:17 pm
That looks nice.
Thu Mar 10, 2011 6:11 pm
Just got the board drilled and the eyelets swaged :isay:
I'll start populating it tomorrow :poop:
Wed Mar 16, 2011 7:32 pm
Didnt get around to populating the board so I'll get around to it on saturday hopefully. Instead I did a test fit of all the stuff I didnt do last time and it all looks to be fine :poop:
Thu Mar 17, 2011 4:29 pm
I r excit to see this progress!
Fri Mar 18, 2011 9:06 am
THIS. Maplifier constructions YES.
Fri Mar 18, 2011 10:56 am
:tu: good stuff :panic:
Fri Mar 18, 2011 8:44 pm
my workbench went as far as actually finishing a true bypass and added purple led to my Hendrix wah. I never use wah anymore, I just had started it a long time ago and just finished it. :facepalm:
Sun Mar 20, 2011 11:24 am
The board is mainly populated now. Just missing a 10K resistor and two 1N4007 diodes which I'll pick up tomorrow.
Wired the preamp heaters too.
:panic:
Tue Mar 22, 2011 7:33 pm
:panic: Looking mappy! :panic:
I actually had some stuff on my workbench recently, but i only took pictures after they were done. :red:
Next time i will have to be more on the ball with the camera.
Tue Mar 22, 2011 7:39 pm
what dat?
:poop:
Tue Mar 22, 2011 7:55 pm
Just pedlols for Devin. A timmy and a mastotron.
I WANT to build an amp, but my next project will probably be something recording-related. Specifically, if i can figure out a ghettocheap way to trick and make my mixer recognize 16 inputs instead of 8 over the firewire, my next project will be the construction of... about sixteen microphone preamps. :red:
Tue Mar 22, 2011 8:01 pm
Cool, I've been eyeing up the madbeans pcbs to build something on. Apparently its not too hard to build a supercollider using a muff PCB so I might look into that.
I read that link, I guess you arent going to be using 1000 batteries to power it though :o
Tue Mar 22, 2011 8:06 pm
You mean an actual particle accelerator, or like a pedal by that name?
If the former, then plz link to article. :idea:
Tue Mar 22, 2011 8:27 pm
Oscillator fuzz unfortunately :dildo:
I'm probably better off building a boost pedal in all honesty though.
Also I have a behringer echo machine with is an echo park clone. Pretty decent delay for not much cash but it stopped working. I finally remembered to bring it home to check up and there isnt any power getting into the pedal! probing the terminals of the DC input socket gets pretty much nil. The adapter gets pretty fucking hot though. It uses the same input as the boss pedals and apparently they arent to great for not shorting so I'm gonna rip that sucka out and try it with a battery snap to see if the rest of the pedal is okay.
Tue Mar 22, 2011 8:33 pm
Adapter getting hot means a short somewhere more than likely. Does the adapter work normally with other pedals(test... carefully?)?
Look for anything that is touching anything else that shouldn't be. If that is one of the plastic behringers, there isn't a whole shitlot that anything can short to, so it becomes more likely that you have a wire or solder blob touching something.
Or, that the wrong power adapter was applied(say, one with reversed polarity, or a 9V AC instead of DC). In that case, you hopefully wold just have a dead diode that would need swapping(prolly SMD, so get out your pointiest iron tip and some tweezers!)
Worst case scenario, the computer that runs the whole damn pedal might be toast. :idk:
Also, that supercollider sounds innnteresting. I am lloking at the schematic, and i may well try to do some of those mods to my own big muff build. :isay:
Tue Mar 22, 2011 9:03 pm
I tested the pedal with a different PSU and it was the same. The PSU itself reads 14V unloaded with a meter.
I'll check the diodes for continuity. There is one under the DC socket which tests okay for continuity but if the socket is shorted then I guess it would anyway :idk:
Wed Mar 23, 2011 8:03 am
Mapz and pedalz are very win :huzzah:
My workbench is too clean at the moment :plot:
Wed Mar 23, 2011 1:24 pm
While poking about over on the slocone forum I stumbled across a genius, if retardedly simple preamp prototyping rig.
Wood and copper nails! Build your maps, and work out the layout at the same time and no need to cut components down to fit in eyelets! no waste, no dicking about.
After this 20Wer is dont I'm stripping my preamp and building a 1ch high gain doofer.
Fri Mar 25, 2011 11:34 am
