View unanswered posts | View active topics It is currently Sun Aug 30, 2026 8:38 pm
Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3
MoChang mixing project. Fancy giving it a mix?
Post Re: MoChang mixing project. Fancy giving it a mix?
Mad Bro Lovin' up in this thread.
Wed May 25, 2011 2:25 am
lol that was nuts Eric :lol: :rawk:
Wed May 25, 2011 2:26 am
I loev yuo guise
Wed May 25, 2011 2:28 am
We lurb u 2, Geofferz.
:D
Wed May 25, 2011 2:30 am
:D
Wed May 25, 2011 2:33 am
metalfanat1c wrote:
What all is on your drum bus? Those drums sound massive.
This.
Fat kick sound FTW.
Waves SSL G Channel on all drum tracks. :love: Like, seriously, having been able to sit behind a real SSL G series a few times now, this thing rules.
Stock Logic compressor acting as a limiter on the snare, -12db threshold, 0db peak limiting. The comp itself is set to 1.5:1. 10ms attack and 4db makeup gain. No modeling, the clean "Platinum" compressor.
OHs are 4:1 Logic FET compressor, 20ms attack and 50ms release.
Room is the Waves CLA 1176, Blackface. Fastest attack and release, all-buttons-in.
Parallel smashed with Cytomic The Glue. Full range with Peak Clip in, HP filter off, fastest attack and release, 100% mix @ 10:1, blended in under the drum bus. Soundtoys Decapitator with Drive on 2 of 10, low and high cut off, tone @ 1:00, mix @ noon, Ampex model.
Master bus is Decapitator on the Thermionic Culture Vulture Triode setting, The Glue again and Waves Pultec shelving EQ cutting and boosting 60hz at once, on 3 (of 10), 10 broad bandwidth, boosting 12k @ 3 of 10, and Waves Pultec midrange EQ boosting 1k and 2k @ 1, and cutting 200hz at 1.
My computer's fan spooled up while I was reading this... maybe I shouldn't try it. :lol:
Wed May 25, 2011 2:58 am
And I'm running it off the internal drive on a laptop, to boot. :wall: Let's just say I had to restart Logic to bounce the mix. :lol: It's saving grace is that it's at 44.1. There's enough instances of Decapitator to bring at least one CPU core to a screeching halt. It's on all busses, almost all tracks have G Channel...
Wed May 25, 2011 10:19 am
Thanqs! :D I plan on finishing this in my spare time; the difficult part is lining everything up. :red: If I really want to go nuts, I'll probably replace the toms, to be honest, or at least layer them up with another sample, reamp the bass through a real rig, and generally get the thing sounding as gigantor as possible whilst still having clarity and separation. The sources already sound good, so there's nothing to fix. :tu:
I like the tone of the snare once it's been clobbered, but I think in the mix it could punch more; I'll probably blend in an uncompressed track under it. Vocals are a work in progress. Probably gonna be a lot of automation on those, but that's typical.
I'm assuming the guitars are the :snax: ? The guitarist in my metal band got the new firmware update, which adds the power section modeling from the :snax: II, and he says- and he's not one to exaggerate- it's like buying a whole new amp. Also, he had to re-dial in all his tones. :lol:
To the peanut gallery- this is what you can do with plain old EZDrummer.
Wed May 25, 2011 10:53 am
This sounds completely huge. Love it.
Thu May 26, 2011 1:28 pm
Coming along nicely.
I won't try to mix it myself, as i would probably just 'accidentally' lose the clean vox... :red:
I like the rest of it though, nice guitars and drums, and i like the way you have got the parts stuck together. Doesn't really play like an almost six-minute tune(meant as a good thing, coming from someone with as short an attention span as myself).
Fri May 27, 2011 5:58 pm
Snaxo's version is fucking filthy, eh? Drums are wildly crunchy. I also dig the vocal treatments there, high drama(i.e. fittingly, for the epic rawx).
Fri May 27, 2011 6:00 pm
Who stickied this?
Sat May 28, 2011 7:41 pm
Beats the trousers off of me. :idk: Maybe joey? I'mma get some foodstuffs now. Garda's taking some time off gigging so I can get to this.
Sun May 29, 2011 2:53 am
hmm, I dids not sticky this......
I'll unsticky it though.
Tue May 31, 2011 12:36 pm
Actually starting to work on this again now that I have the Hackintosh up and running. I'll see what I can make it do. :nods:
I got Waves Eddie Kramer Master Tape and put it on every channel, Waves SSL G Channel on everything...
Sun Jun 26, 2011 6:59 pm
http://dl.dropbox.com/u/13184331/MCTest4.mp3
I know there's bits I genuinely need to go back and fix (like the filter sweep before the end) and I'm not sure if it rocks or sucks as a whole; I keep tinkering with it and think I may have gone too far.
Thu Jul 07, 2011 7:37 pm
I dug it.
Thu Jul 07, 2011 7:45 pm
Mega glue going on here. I think the whole thing's a touch dark though... and the guitars are a little 3k heavy for my tastes. :bangin:
Thu Jul 07, 2011 7:53 pm
The snare wound up pretty dark, and having the bass high up in the mix doesn't brighten it up overall, that's for sure. Striking a balance between the guitars and synth was kinda tough; the guitars were actually getting lost at points behind everything else! I probably did bring the upper mids up a fair bit just to make 'em cut, and pulled the synths back some. I kinda erred on the side of sheer mass here.
Kick, snare and toms I buffed up liberally with my own samples. Bass got duplicated, one track went to SVX, the other went to a modeled 808 for dirt and IIRC Waves LA-2A for additional punishment, with both bussed down to a group and mono-ed. (Logic defaults to stereo groups; I'll swear there was a subtle difference- tighter, somehow.)
Lotsa panning stuff going on with the vocals, a lot of it subtle, and a fair bit of distortion as well, some subtle, some really blatant. A bunch of automation on the reverb send, too.
Guitars got hit pretty hard with Decapitator on the E setting, which wound up really obviously un-smooth on its own, but evens out in the mix. Adds a nice je ne sais quoi. :red: I used Space Designer, the impulse 'verb in Logic Pro, for some room sound on there.
Thu Jul 07, 2011 8:10 pm
Fuking badass dude. Ima send it off to my singer right now.
Fri Jul 08, 2011 5:44 pm
