 NPD
 My trusty Tuna Melt, died. I ordered a Cool Cat trem, because they are so simple, but this came across CL and I got a great price on it. Will report on my findings. It's here at work, have to take it home and properly make some noise wif it
| Fri Apr 13, 2012 11:49 am |
 Re: NPD
Oh, hello! That is interesting. Can you have both running at once, or does it switch between the two? (Either is cool; I keep my Pulsar dialed in for one song live and kinda say "screw it, close enough" for any other time I wind up using it.  )
| Sat Apr 14, 2012 4:35 pm |
 Re: NPD
it switched between the tow rates, nice, little device though. has a blinking LED to advise you of the rate. it's kind of overkill for me, I only use trem on one song right now, but for general noisery, it does what it says well. It doesn't have a wave shape selection though, but uses a sine wave which it what I use anywho.
| Sun Apr 15, 2012 12:08 pm |
 Re: NPD
Whatzit look like on the inside?  Sine is the bast for musical guitar trems, IMO, unless you go for noisy stuff, then a square can aslo be sweet. Trems are one of those things that i always think will be interesting to have around, but then i just don't write enough stuff that calls for them. I have one really amplike trem that i DIYed, and then i have the one in the Electrix rackthing that is all fucking bellsandwhistled up. I don't use either in normal playing though. Even on shit that i put trem on, i have wound up VSTing it. I do want to build something fancy though. No real reason to, because the Electrix is pretty gnar, but i would like to play with the designing of the things a bit anyhow. I am definitely into the extreme fast pseudo-ringmod chopper trem thing too. I would like to fuck with circuits for that for sure.
| Sun Apr 15, 2012 12:20 pm |
 Re: NPD
Very simple on the inside. I will take a piktar for you. One of the rate knobbys can get the rate faster than the other, The instructions inside also have all typed of test points and trim knob information. I will scan this as well for you Chris.
| Sun Apr 15, 2012 3:07 pm |
 Re: NPD
| Sun Apr 15, 2012 3:12 pm |
 Re: NPD
| Fri Apr 20, 2012 9:05 am |
 Re: NPD
Why is "hand built" in quotes? Also, is that the whole circuit board? Or is it just a section of it?
| Fri Apr 20, 2012 3:31 pm |
 Re: NPD
I believe that is the whole thing. I opened it initially and it is very small. I will snap pics this weekend and post them up.
| Sat Apr 21, 2012 10:36 am |
