View unanswered posts | View active topics It is currently Thu Sep 03, 2026 12:09 pm
Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
Free Drum samples
Post Re: Free Drum samples
Probably some shit you have to assign in there. I'm sure there's an SD2/Reaper tutorial out there that could tell you.
Sun Mar 20, 2011 7:39 pm
metalfanat1c wrote:
Slate's samples are kind-of dead sounding, as if they've had the life squished out of them with the stock compressors in Cool Edit Pro or some shit. They also seem to be a bit duller (darker?) than SD2, and there's no real overhead samples or cymbal samples to speak of... usable ones, anyway.
And the snare samples are all tuned weird. Thunk, versus crack. I'll take a cracky ringy snare over a thuddy dead snare any day of the week, personally. Even the piccolo samples sound thuddy. IMO of course.
This is how I felt about the samples I heard as well - I thought it may just be my ears being used to the brightness of the EZDrummer samples. Ages ago on HCAF I mentioned that I thought they sounded a bit dead and boring and they were like "d00d3 that's just because they're not in a mix" and I fell for it :red:
regarding reaper doing multiple outputs, I have no idea how to do that :red: I just put ezdrummer on a single track and do all my drum mixing with the built in mixer. And change the snare to the 13" since the other two sound a bit dead to me.
Sun Mar 20, 2011 7:40 pm
But that would mean, like reading stuff. That sounds like work ...
But yeah, I'm going to go do that right now.
Sun Mar 20, 2011 7:42 pm
Dude, it's pretty easy.
Basically, look in your mixer (SD2's). There will be 1/2 at the bottom of each channel. Click it. Select something else. Then, create a new blank track in Reaper. Click "io" on that track. Click add new receive. Click "New channels on sending track." Select the channels you selected in SD2. Done.
Sun Mar 20, 2011 7:49 pm
Well, it makes all of the tracks in reaper automatically. But, there is just nothing assigned to them. I guess I just need to start assigning to tracks from sd2s interface. I am going to try this tonight.
Sun Mar 20, 2011 7:53 pm
